Old March 30, 2010, 02:09 PM
lcdguy's Avatar
yes both the 9690SA and 9650SE series are great cards. The latter being the newer product. Both provide excellent performance. Both are low profile single port SAS Raid cards. The only major difference is the pci express bus width not that it matters since there is a dumptruck of bandwidth on even pcie x1.
Old March 30, 2010, 05:42 PM
lowfat's Avatar
Both are older cards though. You would want either the LSI 9261-8i or the 3ware 9750-8i now, both the the same card. Much better performers and a lot more cost effective than older RAID cards.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 30, 2010, 05:52 PM
lcdguy's Avatar
oops my bad.
Old March 31, 2010, 04:43 AM
I've done my research and you all have made some compelling arguments.
The 3ware 9750-8i costs $600+ though. Why is this one twice the price of the other ~$300 priced RAID cards? Is it the new factor? Can you suggest a similar card supporting minimum 6 sata drives?
Old March 31, 2010, 05:03 AM
lcdguy's Avatar
mostly because the 8i means it has 8 ports or 2 SAS ports. This means you can either connect 8 sata/sas drives by breakout cables or 2 SAS expander zones for a maximum of 256 dives (128 per sas channel) if there's a 4i version look at that.
Old April 1, 2010, 02:24 PM
Managed to get a hold of an Adaptec aar-2610sa 64mb 6x sata ports.
I'll play with this for a while and then move to something more expensive after benchmarking.
Old April 5, 2010, 10:39 AM
Anyone have an opinion on this card?
Old April 5, 2010, 07:16 PM
lcdguy's Avatar
as far as a raid card goes it's pretty decent. however this is a pci-x not a pci-e card. So unless you have a motherboard with a 64bit pci slot you won't be able to fully utilize the performance of that card. Probably the best bang for your buck card series in the used market is either the dell Perc 5/i or 6/i.
Setting up Raid.. Does it matter what sata ports I use? Yamcha Troubleshooting 9 February 1, 2010 08:17 AM
RAID Card - Yes, No, Maybe? AmuseMe Storage 12 December 17, 2009 07:25 PM
do I need raid card? bumfloss Storage 11 June 27, 2009 05:14 PM
Win-TV-HVR-1600 not finding any channels Shadowmeph Troubleshooting 7 November 5, 2008 07:33 PM
looking for a raid card that does 0+1 cujo Storage 0 March 10, 2008 11:14 AM
