Old March 24, 2010, 06:11 PM
Optix's Avatar
Default Difference Between Two 640GB Caviar Black
Hey folks.
I'm about a week away from pulling the trigger on a new rig and want to pick up a 640GB WD Caviar Black but on Direct Canada there are two models. They both carry the same part number but I'm not sure what the difference is. The only thing that jumps out at me is one doesn't mention a warranty.
Any ideas?
Product link
Old March 24, 2010, 06:13 PM
oem? lets see
Old March 24, 2010, 06:18 PM
Optix's Avatar
It strikes me as odd if one is a retail unit that it would be less than the OEM.
On an unrelated yet related note I see that there are also two versions of Sapphire's Vapor-X 5770. One that is out of stock and one that is in. Different model numbers but I can't seem to find anything on the new card.
Old March 24, 2010, 06:45 PM
go with the cheapest. unless one drive has less cache and that makes a difference for you, doesnt seem to be the case this time
Old March 24, 2010, 11:45 PM
They seem to be the same. They have the same part # and they both have 5 year warranty listed in the specifications. Go for the cheapest one
Old March 25, 2010, 02:59 AM
MonsterSound's Avatar
Default WD 640 Blk
Possible PM at NCIX or MemoryExpress (freeShip) $63.99 at Linke
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / evga GTX780 SOC / MSI Z77A-G45 / 8gb G.Skill 2133 1T / 30" 2560x1600 / Antec P280 / PCP&C 950w / Intel 520 SSD 240gb / Eclipse / G3-Lazer / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
Old March 25, 2010, 04:45 AM
I believe it's only a mistake they made. Just make sure that you get the right part # if you order the cheapest though.
Old March 25, 2010, 05:48 AM
Optix's Avatar
Good stuff. Thanks all.
Oh, and it looks like Linke doesn't ship to Canada.
Any thoughts on what appears to be a refresh of Sapphire's Vapor-X 5770?
2xWD Caviar Black 640 GB or 1x WD Caviar Black 1T Mulder Storage 4 December 19, 2009 04:17 PM
WD Caviar Black 640GB'ers in Raid 0 Killswitch Storage 16 November 30, 2009 10:33 PM
WD Caviar Black 640gb Jonwall Storage 27 May 16, 2009 06:28 PM
640GB Western Digital Caviar Black WD6401AALS HD Tune Result Oversized Rooster Storage 12 November 11, 2008 04:24 PM
