Old March 23, 2010, 04:17 PM
Patramix's Avatar
Default hot swap question
Quick question, haven't used a hot swap in years, and i just got a new 800D, i got 2WD back 1TB and 500gig's with win 7 64bit
my question is how does it work for the hot swap? can i remove my backup drives (wd black) and insert my other backup drive while power is on? do i need to do something in windows first?
thanks
sorry if this is laying around here somewhere dint see it.
All of life is forged from Hell, Yet from its beauty our legacy began.
My Boinc Stats
Old March 23, 2010, 04:24 PM
MarkOne's Avatar
you have to set the drive in AHCI mode in the BIOS
Old March 23, 2010, 04:28 PM
lowfat's Avatar
As long as AHCI is enabled (and w/ some motherboards hotswap as well), you should be fine. Although it is a good idea to use the 'Safely Remove Hardware' first if possible.
Old March 23, 2010, 05:13 PM
Patramix's Avatar
kk thanks guys, need to look in bios now.
My Boinc Stats
Old March 23, 2010, 05:22 PM
Patramix's Avatar
humm my current board might not do it, EVGA 780i sli board or i wasn't looking hard enough.
My Boinc Stats
Old March 23, 2010, 05:32 PM
MarkOne's Avatar
wait a minute, it's not simple to change the seting from IDE to AHCI after the OS is install, you have to do it before
Old March 23, 2010, 05:36 PM
Patramix's Avatar
lol now you tell me lol
good thing my current board doesn't seem to support it. don't matter much anyways, i just ordered the p7p55d-e pro and a shiny new i5 so ill need to reinstall win 7 anyways.
i just need to keep in mind to activate that AHCI option before.
thanks for the info.
My Boinc Stats
Old March 23, 2010, 06:21 PM
gingerbee's Avatar
just install with ahci drivers first then if needed you can always just turn back to ide and reboot simple and done why bother to even use ide at all.jmo
Old March 23, 2010, 07:07 PM
Patramix's Avatar
does win 7 come with those drivers or do i need to download them and input the drivers during install?
My Boinc Stats
Old March 23, 2010, 07:48 PM
grinder's Avatar
from my experience it's a 50/50 chance you will need the AHCI drivers on a USB key when you load windows for the first time with AHCI enabled.
Simple CPU Swap Vdub90 New Builds 9 December 5, 2009 07:26 PM
Hot Swap Hard drive grifter11 Storage 8 July 18, 2009 12:39 PM
Hot summer days, hot computer problems. NightRain Air Cooling 17 July 6, 2009 09:11 AM
Motherboard Swap? tyreman CPU's and Motherboards 4 April 1, 2009 08:32 PM
Notebook LCD Swap Stinger Display Units 0 October 6, 2007 06:14 PM
