Originally Posted by gingerbee yes you have to assign a drive letter for the os to see it no matter what. if there formatted. ie not raw then it should be seen automatically.
1. plug the drive in
2 assign a drive letter/ format drive
3 see hdd by the os start using it done  |
So I did an experiment earlier and I don't understand why Windows 7 Professional is doing this. When the computer boots to the desktop for the first time, I can't see the so called "data drive". I have to go to disk management, add a drive letter, and then it'll appear. However, if I reformat the computer, the same thing would happen and I would have to assign the drive letter to the drive again. It's very annoying! The files that I put on the drive is still there though!
