Old March 18, 2010, 04:24 PM
Delavan's Avatar
Default Solved!!!!!
Hi!
Now that I received my Vertex 120GB from NCIX ($299 after MIR deal), I installed it (it runs the latest firmware 1.5 from the factory!).
It was my first windows 7 install and my first try at a 64 bits OS on my desktop.
I did everything I could to make it go flawless.
Anyway, sometimes I get a hang right after the Windows startup screen. It freezes at the first screen, right before the taskbar shows up.
What I did:
-Set BIOS to ACHI
-Plug SSD in SATA 1 (ICH10) on P5Qpro
-Plug optical in SATA 6
-reset my overclock for the install.
-I did read a LOT on SSDs and tweaks before the install.
-I tweaked the SSD by disabling a few things, as per OCZ forum's recommendations.
Ran windows. It took a LONG time to install.
I got the freeze everytime I rebooted after installing any kind of security software (always at the same moment). I tried my ISP provided one (win7 64 compatible), then I tried Avast!, then finally Windows security thingy.
Anyway, the freeze doesn't happen everytime now, but I suspected my Audigy 2 ZS (even with latest win7 drivers)...I took it out and enabled onboard audio.
Then I suspected my overclock...I increased the Vcore a little bit, seems a little better. Is it even possible that my overclock could be causing a hang in Win7 64 after a year of rock-solid stability in Win XP pro 32bits???
I'm a little loss here. Is it the SSD or something else that causes that freeze? Win7 itself?
My RAM? My Gskill ram DDR2-1000 runs at 2.1v @ 900mhz, seen as 2 X 2GB in Windows.
Any idea so I can redirect this thread where it belongs?
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
Old March 18, 2010, 04:43 PM
MarkOne's Avatar
you don't install an OS with an OC ... reset the bios
Old March 18, 2010, 04:51 PM
gingerbee's Avatar
well i can tell you that there have been rare cases of people on the gskill forums running the sale firmware had a big 10 to 15 seconds where the system would freeze.
and if your OC is stable installing an os with it OCed is fine i have done it so many times i lost count but you must be sure it's stable @ markone maybe you should have said you wouldn't have done it but a lot of other do it all the time this is a matter of opinion. which is silly if your system is stable it's stable period.
Old March 18, 2010, 07:19 PM
Delavan's Avatar
Mark one, like mentioned in my original post,
Set BIOS to ACHI
I did run the install at stock clocks.
But I now use AHCI, a new 64 bits OS, a SSD, so a lot of new things to consider as being one of the "possible" cause. So I'm puzzled.
Old March 18, 2010, 07:49 PM
gingerbee's Avatar
well the os and and ahci, either these work or they don't period so i would check the ssd.
Old March 18, 2010, 07:54 PM
MarkOne's Avatar
don't blame me guy ....you are very confusing in the way you explain, why you will rise the volts of your OC if you are on stock...
Hi!
What I did:
-Set BIOS to ACHI
Old March 18, 2010, 08:05 PM
MarkOne's Avatar
I stick on it you don't install an OS on an OC... if it's only for remove it as problem
and for the Audigy... I always install them after the OS is done, and all other drivers are update.
The Op play with to much thing.. like by exemple he remove the Audigy to install the onboard sound card.. 3 differents anti-virus.
he should reset the board...remove the add on card. disable the on board sound card if he plan to reinstall the audigy later, and redo a fresh install. and make sure those ram are at stock voltage too.
And try to put the dvd on the other controller too.
Old March 18, 2010, 08:16 PM
gingerbee's Avatar
well once again this is your opinion overclocking does not effect the data if your system is stable it's stable. and you yourself know that you don't have to install on os to an hdd/ssd for an overclock.
Old March 18, 2010, 08:18 PM
gingerbee's Avatar
. just work everything backwards
Old March 18, 2010, 08:25 PM
MarkOne's Avatar
my opinion is base on this : you always give yourself the best chances when you do something. so you eliminate things that can create problem, and when you make trouble shooting, you change only 1 parameters at the time.
for the OC. the facts the Oc was stable on XP don't means it will be on 7, especially if the drivers are not install, so you install the OS the drivers you update the Window and after you OC.
[SOLVED] 2 gen my second gen customize computer is not working [now its ALIVEEEE!!!!] CTA Troubleshooting 37 August 31, 2008 06:50 AM
