Old March 12, 2010, 12:16 PM
Default enclosure for SATA 2?
I'm wondering what is a good enclosure for HDDs. Is a passive aluminum enclosure still okay? How do I know if it will support SATA 2 speeds? If I go with eSATA and a 'Green' drive for storage, I'll want the fastest speed I'm allowed, right?
I have a Vantec NexStar 3, currently, with a drive. It gets a bit warm but I think it's okay. Somebody on Newegg says those enclosures don't support Sata II. Huh?
Anyway, I hope someone can recommend some. I will want to get one when I buy a drive. I thought if I go with a 'green' drive, I don't need an enclosure with a fan. If I bought a standard HDD at 7200rpm, I might want one with a fan? My HDD in the Vantec I have now is a standard HDD but I think the temps are acceptable....hopefully...
Which enclosures do you recommend?
Old March 12, 2010, 12:47 PM
lowfat's Avatar
You really don't need SATA 3Gbps support in an external enclosure anyways as the drive won't hit those speeds. I've used plenty of the Nexstars w/o any issues.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 12, 2010, 01:44 PM
krazyups's Avatar
I'm currently using the Nexstar with a regular 500 gig hard drive using esata, and it works great. I keep forgetting it's esata until I go to use a USB2 external ... big speed difference obviously.
-Steve
Old March 12, 2010, 02:05 PM
Okay, sounds good. Now, I have to decide on a drive.
Not sure I want to go with a WD EARS drive or not.
I guess I was really asking about an enclosure because my drive choices are these:
WD15EARS or Samsung F2 EcoGreen (any capacity) or Samsung F3 1TB (a 7200rpm drive)
Old March 12, 2010, 03:06 PM
Delavan's Avatar
I like this one, although I never used it personally:
Antec Veris MX-1 Actively Cooled External 3.5IN Hard Drive Enclosure USB2.0 eSATA Black
Reg price is $59.99 tho, could be PMed to around $49.99
I have a Seagate Freeagent 1TB USB that I MIGHT upgrade to a MX1 enclosure, if transfer speeds from USB to eSATA are worth it.
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
Old March 12, 2010, 10:58 PM
The EARS has the bigger cache than the EADS, but a green is a data drive anyway. I picked up a couple of the 2TB in the nicx sale last week, mounted one internal, swapped it out with my 150GB raptor data drive, holds so much more eh. The problem with external enclosures is always heat, not sure if I'd trust a passive cooling system, for a sealed type external, I'd want some fannage. What I've had for a few months is one of the dual drive Thermaltake BlacX's which can be used usb or e-sata. However, I rarely use it, internal is much healthier for the drives.
As mentioned above, e-sata is the way to go, much faster than the usb interface. And, as an added bonus, when your drive appears toasted, diagnostics and recovery progs run much better when the connection is e-sata. No extra level of translation back and forth through the usb.
[FS] 1 Day old WD Black 1TB and e-sata enclosure. Mike_E Buy/Sell & Trade 2 July 29, 2009 10:14 PM
[FS] WTT/WTS DVD's for cash/sata optical drive/sata hdd's/ Geforce 9800 or better The MAX Buy/Sell & Trade 4 April 16, 2009 04:22 PM
WD 640 Black SATA ....Not SATA 2 rjbarker Storage 10 January 20, 2009 12:40 AM
Review of 3.5 Vantec Nextar 3 Sata Drive Enclosure Dashock Storage 5 May 7, 2008 04:32 PM
