Originally Posted by lcdguy |
This is my rig - a Supermicro X8DAi, using a Norco RPC-270 2U case. I bought the 9650 for the low-profile form factor and the fact that I did not need external ports, like the 9690. This is an old pic, without the card and array (Sammy F1s) installed.
Originally Posted by MarkOne So bad you already order a raid card . because with the Windows Home Server, you will not have need it with the stuf you have. |
I use W7 Ultimate, and did not want to either re-install an OS, or use the Supermicro onboard (software) RAID solution.
