Raid 1 keeps Rebuilding Question
I am trying to setup a Raid 1 using the Nexstar MX enclosure. The enclosure's eSata is attached
to my motherboard's Jmicron port. Yesterday it started rebuilding. This morning I found the two Hard Drive access lights on the enclosure blinking, so I assumed the rebuild has finished. I rebooted my system, but the enclosure is showing that rebuilding is stated again ! Now its at 35%. How ofter does a Raid 1 system need to rebuild ? Is rebuilding a continuous process with raid ? I have not loaded any file to the main drive.
I am getting frustrated.
__________________ ASUS P6X58D-E; INTEL i7 950 ; NOCTUA NH-U12P; PNYGeForce GTX 460 OCX ; LIAN-LI PC-V1020 CASE; SEASONIC PLATINUM 860; WINDOWS 7 PRO 64-BIT. |
