Old February 13, 2010, 09:39 AM
Sui's Avatar
Sui Sui is offline
Default Large IDE (PATA) HD
I know it's hard to come by but due to the home server (P3) does not have extra PCI slot for SATA controller, I would have to upgraded an IDE (PATA) 500GB to a larger PATA drive. I know it sounds silly but tried to minimize the budget... I think 750GB IDE was available.... what about 1TB?
Anyone know where I can get one besides on eBay?
TIA
Hi there... I am new to HWC! Feedback:
Heatware | RFD | HoFo
Old February 13, 2010, 10:40 AM
MarkOne's Avatar
Not sure I understand well, every computer stores , and online stores have 1, 1.5, 2Tb drives, unless you means you want a used one
Old February 13, 2010, 10:44 AM
Sui's Avatar
Sui Sui is offline
@MarkOne, thx for your reply but I need IDE (aka PATA).
Old February 13, 2010, 11:00 AM
Toyoracer's Avatar
How about using sata to ide card, http://ncix.com/products/?sku=34244&...cture=Addonics
Old February 13, 2010, 11:22 AM
Sui's Avatar
Sui Sui is offline
Originally Posted by Toyoracer View Post
Great... it's an alternative. Thx!
Vote: Eyefinity or Large Panel CMetaphor Display Units 36 December 10, 2009 08:11 PM
Suggestions for a large ATX with.... lowfat HTPC Systems & Software 26 September 25, 2008 10:29 AM
almost prefect mouse for large hand? CTA Peripherals 32 September 9, 2008 07:42 PM
Large Increase in vCore From 3.6 - 3.8Ghz rjbarker Overclocking, Tweaking and Benchmarking 17 April 9, 2008 09:14 AM
Large project James_8970 HTPC Systems & Software 6 January 9, 2008 10:44 PM
