Old February 11, 2010, 07:23 PM
Default How to Clone Dell's Recovery Partition to Another Drive
Hello,
I received my new XPS 8100 a few days ago, and I would like to replace its hard drive (I planned on doing it before I ordered the XPS system). I would like to replace it with Western Digital Caviar Black 2TB, but while I have cloned drives in the past and generally familiar with the procedure, I have never cloned a Dell's drive. As you can see from the attachment below, it has 3 partitions (two of which seem to be hidden), I would like to preserve these partitions because they provide an easy way to restore the system to its original Dell's configuration, but I do not know how to do that. I am thinking of using Acronis True Image, is that a good idea?
Also, on a slightly unrelated note, in WD CB 2TB review on this site (Conclusion section), it says in part:
In fact, if you portioned off the first 200GB or so of the Black 2TB the resulting “C Drive” would be a force to be reckoned with even against SSDs.
What does it mean? Is it an actual recommendation to partition the drive as described for the purpose of installing Windows 7 on the 200 GB partition?
Thanks!
Old February 11, 2010, 07:41 PM
gingerbee's Avatar
you just need to clone the drive. well that is how i did it many years ago. the easiest way should be seatools it should have a clone feature.
Old February 16, 2010, 07:17 PM
I figured it out. I have tried a number of different cloning software programs, but Clonezilla (which is free) is the only one that worked. Others worked too but the Dell's recovery partition was unusable.
data recovery from an untouched drive bissa Troubleshooting 2 May 6, 2010 01:45 PM
data recovery external drive cappaj1 New Builds 3 June 7, 2009 08:47 PM
Partition 640gb drive... or not??? somecanadianguy Storage 19 April 1, 2009 08:23 AM
Partition Recovery? jgerber O/S's, Drivers & General Software 9 February 23, 2009 06:51 AM
Fat Partition to NTFS Boot Partition PaxeSalute O/S's, Drivers & General Software 1 May 2, 2008 01:28 PM
