Old February 5, 2010, 01:54 PM
Default Setting AHCI for SSD??
I could use some help here. Before I load my OS (WIN 7 64 Pro) I was told to set my BIOS to AHCI for my Intel X25-M 80gb drive. I was able to set AHCI in STORAGE CONFIGURATION (my choices were IDE, RAID, AHCI) and in MARVEL 9123 SATA CONTROLLER (Choices were Disable, IDE, AHCI) but in the J-Micron SATA/PATA controller the only choices were (Disable and IDE).
Do I need to set everything to AHCI or does it matter?
Thanks for the help.
Jim
ASUS P7P55D-E Pro - Intel i7 860 - Zalman CNPS 10X Quiet - 4gb G.Skill Ripjaws DDR3 1333 CL7-7-7-21 1.5V - Intel 520 Series 240 GB SSD - WD Caviar Black 1Tb - Corsair TX750W - Sapphire Radeon HD 5770 1 Gb GDDR5 - DVD Drives X2 LG GH24LS50 - Coolermaster CM690 II Advanced - Win 7 Pro 64
Old February 5, 2010, 01:57 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
As long as the controller you are plugging the drive into is set to AHCI and you use the MS AHCI driver in Windows 7 for it. It doesnt matter.
TBH...and if I remember correctly, the JM chip on that board is used for the Pata port....which cant be used for your SATA SSD anyways. ;)
Old February 5, 2010, 03:09 PM
AKG
Thanks for the info. Much appreciated. I've left the Marvel controller on AHCI anyway. I don't have anything connected to it right now.
Jim
Old February 5, 2010, 05:38 PM
rjbarker's Avatar
Jim
Even if you install W7 on your SSD in IDE Mode you can always change the SSD to AHCI Mode after the W7 installation, not a big deal, little configuring in the Registry is all.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old February 7, 2010, 03:03 PM
BrianHanna's Avatar
should i be seeing that?
i set it to ahci in registry and then bios, from what i can tell i did it properly?
Asus p6x58d-e / i7 930 @ 4ghz / G.skill 1600mhz 2x3gb 9-9-9-24 / Corsair TX750 / XFX HD 6850 1GB x2 @ 870/1070/ Coolermaster HAF 932 / Noctua nh12-up / Western Digital 500g Caviar black /Western Digital 1TB Caviar black 60Gb/ Seagate 7200.11 500g / OCZ Vertex 3 SSD / Samsung 2253BW / G5 / MX518 /
Old February 7, 2010, 04:12 PM
rjbarker's Avatar
Looks like it....part of AHCI Mode is showing the "Hot Swap" capabilities, that is "Safe To Remove Devices".....
I had my W7 Install on my SSD in IDE Mode, changes in my Registry included "installing W7 AHCI Drivers" from IDE....I'd have to go back to my Registry for the "exact steps" was about 3 months ago I did this, I know it worked fine.
HKEY_LOCAL_MACHINE / SYSTEM/CurrentControlSet/services/msahci/start (RHS) - change value to "0"
Reboot
MARK 11: 32.530
Old June 2, 2010, 04:06 AM
sswilson's Avatar
Does this mean I shouldn't be using the AMD chipset AHCI drivers for win7 64bit?
Old June 7, 2010, 03:03 PM
Pankie's Avatar
I have an asus p6t, and when I first picked up my SSD I made the mistake of using the jmicron sata ports. I think all that he's saying is to use the proper sata ports that will let you use the onboard controllers and not limit speeds. Your drivers should be fine, but make sure you're using the proper controllers.
Ottawa !
Will enabling AHCI boost performance? Matt Storage 17 February 20, 2010 07:22 PM
little help setting up please marcons HardwareCanucks F@H Team 1 April 17, 2009 11:56 AM
Need help setting up my raid. sheepdogexpress CPU's and Motherboards 9 March 27, 2009 10:50 AM
Fatal1ty setting Computergeek Audio 2 July 3, 2008 06:04 PM
IDE to AHCI sircuster Storage 5 February 19, 2008 01:55 PM
