Old February 2, 2010, 05:35 PM
rjbarker's Avatar
Default External HD Query
Ok....so I've had enough of packing a "handful" of Jump Drives back n forth to work every month and having to delete stuff in order to make room in a pinch.
So, looking for a 320 - 500 GB (or more External Drive) that is small n lightweight. Seen a few that look good on NCIX for reasonable price, may even go 1TB.
Question is:
- is eSATA a faster means of transferring Data then typical USB 2.0 ? Both my Desktop and Notebook have eSata, so should I go eSata + USB 2.0? Is the speed difference significant?
Thanks in advance
Its alright..found my answer...eSata it is!
Ah not into packing around power adpaters and crap....think USB 2.o will be suffice as no huge file transfers...likely go with this one
Buy Buffalo [HD-PE500U2/BK] Buffalo MiniStation Cobalt Blue Onyx 500GB Portable External Hard Drive USB 2.0
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
Old February 3, 2010, 12:53 AM
FlyingFish's Avatar
Newegg has a 640gb 2.5incher up for $119.99. Might be worth checking out
Newegg.ca - Western Digital Elements 640GB USB 2.0 Midnight Black Portable Hard Drive WDBAAR6400ABK-NESN - External Hard Drives
Old February 3, 2010, 01:57 AM
odis172's Avatar
What about a usb/esata enclosure, then buy a cheap drive and pop it in?
something like
NCIX.com - Reviews of Eagle Tech ET-CS2PESU2-BK 2.5IN SATA to USB/ eSATA Black External Enclosure W/ Built-In USB Cable - ET-CS2PESU2-BK.
Now im not 100% sure, but it would make sense if you only require the ac adaptor when using esata.
Laptop: Lenovo T420 - Core i5 2520 - 8GB DDR3
Server: 2 xeon E5530 - Asus Z8N-D6 - 12GB DDR3 - 8x 500GB raid 50 - Perc 6/i - Compucase RA448A00
Old February 4, 2010, 03:55 PM
rjbarker's Avatar
^^^ Thanks guys...already purchased and already delivered WD 320 GB USB 2.0 2.5"....its perfect for me needs, small n light with more than enough Storage Space and only $100 (including taxes / delivered to my door ;)
Timespy: 18.613K
MARK 11: 40.185K
Network Switch(es) Query Shftup Storage 7 January 15, 2010 05:23 PM
Fallout 3 AA and AF Sampling Query rjbarker Gaming 8 December 24, 2008 12:55 PM
Intel Burntest Query rjbarker Overclocking, Tweaking and Benchmarking 22 December 9, 2008 12:06 AM
QX9650 Query.. rjbarker CPU's and Motherboards 11 December 6, 2008 07:29 AM
TJ09 Fan Arrangement Query rjbarker Air Cooling 3 November 12, 2008 07:24 PM
