Old January 30, 2010, 11:05 PM
Shadowmeph's Avatar
Default I have never used\tried raid
I just bought 4 hds and would like to try raid on this build , I made this build primarily just to try new things and raid is one of those thing so I could use help with this
Old January 31, 2010, 06:15 AM
Jack Rabbit's Avatar
Are you looking for size, performance, or redundancy?
- James Graham
Old January 31, 2010, 06:45 AM
gingerbee's Avatar
so play around with some raid setups.
Old January 31, 2010, 10:23 AM
Post Raid setups
I would go Raid 5
Fast when needed, redundant when need. and most of all cool
But obviously depending if your doing True RAID,Fake RAID or software RAID
Old January 31, 2010, 03:01 PM
Sui's Avatar
Sui Sui is offline
same to me too... I wonder if changing to Raid 1 would really see some significant improvment over speed (say Windows load up and over all performance)
Hi there... I am new to HWC! Feedback:
Heatware | RFD | HoFo
Old January 31, 2010, 03:43 PM
Lpfan4ever's Avatar
coughcough
RAID1 is mirroring, not striping
coughcough
Originally Posted by encorp
Code:
<firebane> slightly used
Old February 4, 2010, 10:30 PM
Raid1 = Mirror Both drive are the same
Raid0 = Data is written on both drive and both drive are used at the same time
Raid5 =
[wiki]
RAID 5
Striped set with distributed parity or interleave parity requiring 3 or more disks. Distributed parity requires all drives but one to be present to operate; drive failure requires replacement, but the array is not destroyed by a single drive failure. Upon drive failure, any subsequent reads can be calculated from the distributed parity such that the drive failure is masked from the end user. The array will have data loss in the event of a second drive failure and is vulnerable until the data that was on the failed drive is rebuilt onto a replacement drive. A single drive failure in the set will result in reduced performance of the entire set until the failed drive has been replaced and rebuilt.
[/wiki]
Old February 4, 2010, 10:39 PM
Lpfan4ever's Avatar
I don't know where you're getting that information from Megaclocker. I'm running RAID0 right now. If RAID0 was mirroring, and not striping (which is the faster one), then my two 500GB hard drives would end up showing as 500GB to Windows. I'm pretty sure I'm not blind, as my OS reports my C: drive as being a single 1TB drive.
Code:
Old February 4, 2010, 10:53 PM
sorry switched raid 0 and 1.
I guess I need to go to sleep.
Edited
Myself currently using a raid0 would recomment the OP to do one with 4 drives. Raid 5 would be nice also but a little bit slower.
Old February 5, 2010, 08:09 AM
Fudd Rucker's Avatar
What I did was run my 2 x WD blacks in RAID0 with select folders that do a daily backup to my 1TB WD green. Setup is signifigantly faster with a 2 drive array, a 4 drive array would be damn fine.
I couldnt think of something snarky or interesting to put here this time around.
raid 0 Sharp-Shooter Storage 3 December 24, 2009 05:00 PM
Raid 0, never more MarkOne Storage 12 November 28, 2009 09:47 PM
raid 51? bissa Storage 2 September 15, 2009 07:06 PM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
raid help Jhayman Troubleshooting 9 November 8, 2007 02:10 PM
