Old January 19, 2010, 09:37 AM
BT!'s Avatar
BT! BT! is offline
i tried whats posted in post 4 here and it says trim is enabled.
Updated P128 firmware - how do i enable TRIM? - The Corsair Support Forums
Old January 19, 2010, 09:40 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Originally Posted by MarkOne View Post
AkG you told me to install it in IDE mode , so do I have trim working or not ? ( it's enable )
Yeah I know and sorry. I used to recommend that (and run in IDE myself). Then more information came out very recently from multiple sources and it looks like IDE may or may not work and there is way to many variables to be sure right now. MS AHCI driver does work and there has been no reports of it not working. This is the downside to bleeding edge as everything is new and there is gray areas till things get sorted out. Funny thing is...wiper.exe works perfect in IDE mode. So it is not a driver issue or controller issue per say, rather just the IMPLEMENTATION of TRIM that sucks right now. Luckily, this should be one of the last major bumps that SSDs have before working "right out of the box".
AHCI is a royal PITA but its the only way that we know of right now that WILL work w/ TRIM with no guess work.
Sagath's Avatar
Originally Posted by BT! View Post
i used my other system to update to 02hd, and i realize my mobo is the problem, i'm just curious as to where the "enabling" is located? is it toolbox that is used to enable trim?
Windows 7 defaults it 'on' if it detects a SSD when installing. If you dont do a clean install, you can force it on at a later date. Google that, I dont have a link handy. As for IDE --> AHCI, that too is possible post install. Check Guide * Windows 7 Ultimate Tweaks & Utilities * - OCZ Forum out for how.
Old January 19, 2010, 09:53 AM
lowfat's Avatar
It will always say it is enabled. Doesn't mean that the SSD is receiving the TRIM commands.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old January 19, 2010, 10:12 AM
MarkOne's Avatar
The registry tweaking is easy to do . is it gone work fine after ?, I guess the reactivate will be force. if so may be a good time to change the motherboard and make a fresh install. We back at the square 1 when I said SSD was not yet mature.
Old January 19, 2010, 10:18 AM
AkG's Avatar
AkG AkG is offline
The issue MarkOne for BT! is the drive being recognized by the toolbox. The toolbox does (IIRC) have a manual TRIM option that works in IDE or AHCI mode (just like wiper.exe). So if he can get it to bee seen on the "POS" mobo he will be golden. If it cant be seen...thus my worst case scenario options.
Old January 19, 2010, 10:21 AM
MarkOne's Avatar
So I can install the tool box and use the manual trim, honestly that's even an option that I prefer to auto trim
Old January 19, 2010, 10:24 AM
AkG's Avatar
AkG AkG is offline
LOL, yeah you are like me MarkOne. SPEED NOW!!! and let me wory about cleaning up afterwards. This is why I am such a fan of OCZ Indi drives. 1.4.1 ITGC firmware is perfect for me. BUT that auto setup for manual trim the toolbox has (IIRC its called something like "SSD optimizer" or some such) is sweet to. ;)
Things like this is why I always say there is TWO best options in the SSD market right now and not one like some Intel fanboi's say. Intel and Indi, both have their pros and cons. YMMV etc etc
  #19 (permalink)
Old January 19, 2010, 10:27 AM
MarkOne's Avatar
Originally Posted by AkG View Post
LOL, .This is why I am such a fan of OCZ Indi drives. 1.4.1 ITGC firmware is perfect for me. ;)
you should have insist on this one. Next time, actually may be very soon. if only I can stop this PPD craziness
  #20 (permalink)
Old January 19, 2010, 10:31 AM
AkG's Avatar
AkG AkG is offline
TBH the more I use 1.4.1 the more I like it. But I'd never insist on one SSD over the other. Its a Ford vs Chevy thing and I can easily see where Intel's solution is better fit for other people.
Will enabling AHCI boost performance? Matt Storage 17 February 20, 2010 07:22 PM
A-Data Updates XPG SX95 & S592 SSD with New Windows 7 TRIM Firmware FiXT Press Releases & Tech News 4 January 12, 2010 03:38 PM
Intel Releases Solid-State Drive Toolbox and TRIM Firmwave Update for SSD's [PR] FiXT Press Releases & Tech News 6 October 28, 2009 01:45 AM
Which SSDs have Auto-Trim function? AERo Storage 31 October 15, 2009 06:17 AM
Enabling Second monitor causes Hang Eagle Eye Troubleshooting 10 January 31, 2009 01:43 AM
