Old January 14, 2010, 09:50 PM
norfolk's Avatar
Default Should I go SSD or A WD Velociraptor
What do you guy"s think any help here would be great The HD will be used for windows only
Thx
Old January 14, 2010, 10:01 PM
sdd for sure. raptors are overpriced.
Old January 14, 2010, 10:11 PM
norfolk's Avatar
Really? are they that much better
Oh I should add $ is not a problem here.
Old January 14, 2010, 11:27 PM
If $$ isn't a problem. Grab a couple Intel X-25Es and raid them up on a hardware raid controller for mind boggling transfer rates.
Since a raptor isn't that much less than an SSD, there's no point in having a raptor. They're just too slow compared to SSDs.
Old January 14, 2010, 11:44 PM
Raptors are not as reliable either.
Raiding SSDs is not really recommended, since you lose TRIM support, as of now anyway.
Also, with Intel SSDs, you can make them last a crap load longer just by having more free space. Up to 3.5x more endurance before they die. By far the best and the only SSDs worth getting right now.
Old January 15, 2010, 01:06 AM
Jake_HT's Avatar
I don't believe raptors were ever worth the money... SSD's are still expensive, but way faster than raptors, especially demolishing them in access times.. and if money isn't an issue you should have a few SSD's..
http://jakeht.deviantart.com/
Old January 15, 2010, 06:29 AM
norfolk's Avatar
Awesome thx for all the Help I guess it"s SSD"s FTW.
Old January 15, 2010, 06:42 AM
Raserei408's Avatar
Here's my problem with VRaptors:
They cost upward of $200 for 300GB. Now, WD Caviar Black 2TBs have better performance than the VRaptors for $300 and have 6.66x the capacity. SSDs have worse price / capacity, but at least they're significantly faster.
As for getting SSDs, I'd get either an OCZ Vertex or a Corsair P series.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
Old January 15, 2010, 07:03 AM
norfolk's Avatar
I was just over at the Canada Computers web site looking Looks like I will be going the OCZ way I just have to wait till they get stock.
Old January 15, 2010, 07:07 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Grab a pair of Vertex's (or Vertex EX's if as you say money is not a concern). Drop 1.4.1 onto them (ITGC) and forget about trim. Trim is slower and as others have said....its hit or miss with RAID.
Yeah the Corsair P is Samsung based and are simply not as good as the X line. The Corsair X series is the same as the OCZ Vertex, Patriot Torqx (not the Torqx 28 though its a Sammy), GSkill Falcon, etc. BUT only the vertex has ITGC right now.
Where there are rumours of a new 600Gb Vraptor I would not recommend them right now. VRaptor's have their place but they are showing their age and thus are not my first choice for non SSD systems right now.
Western Digital Caviar Black or Velociraptor? Jacka Storage 13 July 23, 2009 06:56 PM
Is VelociRaptor worth it? fire_storm Storage 8 July 22, 2009 11:34 AM
[WTB] 1TB Hard Drives and/or 300gb Velociraptor Jamz Buy/Sell & Trade 4 February 24, 2009 10:29 AM
How much of a difference will a velociraptor make? Roger Franklin Storage 13 October 15, 2008 08:17 PM
New WD VelociRaptor 300GB On it,s way Tomvill Storage 59 August 27, 2008 08:03 AM
