Old January 13, 2010, 08:05 AM
Default Raid Question
Thinking about adding a second 150gb raptor to the system raid 1 or 0 Not sure yet.
Question is, Whats better
On board raiding software(Motherboard)
Or Using a Adaptec raid card.
I found a BNIB Adaptec 1220SA on my shelf.
Not sure if the card is any good for Raptors either.
Thanks for the help.
Old January 13, 2010, 08:21 AM
MarkOne's Avatar
This is not a Raid card controlled with it's own processor, it's only to add more drive to a system , your on board Intel raid chip will do probably better . A good raid card will cost you more than 1 and even 2 SSD, so the choice is clear
Old January 13, 2010, 08:58 AM
gingerbee's Avatar
just use on board.
Old January 13, 2010, 09:28 AM
Strange... The box says RAID CONTROLLER.
Features include
Raid levels
0,1,JBOD
Old January 13, 2010, 09:43 AM
MarkOne's Avatar
Features include
Raid levels
0,1,JBOD
ya but your box don't say Raid controller with on board processors. anyway if you think you can make miracle with a $ 60 cards..go for it
Old January 13, 2010, 10:06 AM
gingerbee's Avatar
without a on board processor it's point less. jmo
Old January 13, 2010, 10:35 AM
See Now im confused, They sell it as a Controller, But its now... WHat am i missing here?
Is it just software then to run on a PCI card?
Old January 13, 2010, 11:56 AM
gingerbee's Avatar
ya it just software all the work is still done on your machine. which your onboard will do fine ( if available forgot to ask )
Old January 13, 2010, 12:38 PM
Rampage Extreme...
Old January 13, 2010, 02:17 PM
MarkOne's Avatar
humm.... it's like I know a guy who have the same board
all true you can use the Asus raid Bios ( red plug ) use the Intel Raid Bios , the blue connector
Question on Raid 1 Bojamijams Storage 13 October 3, 2009 12:23 PM
Question on ICH10R and RAID Bojamijams Storage 8 July 23, 2009 08:22 AM
I have a question about RAID... The MAX Storage 16 May 8, 2009 02:30 PM
RAID Question Wein13 Storage 7 October 12, 2008 06:15 AM
RAID question miggs78 Storage 17 August 30, 2008 03:12 AM
