-   -   Verical vs Horizontal Hard Drive Mounting (http://www.hardwarecanucks.com/forum/storage/2717-verical-vs-horizontal-hard-drive-mounting.html)
Johnboy September 27, 2007 11:31 AM
Hi everyone,
I'm a short time lurker...first time poster :bleh:
Does it matter if you mount a hard drive vertically vs horizontally? I ask because I was doin research on the new antec p182 case and someone mentioned that they would NEVER use a vertical mounted hard drive computer case (I think their point was they have been around awhile and have seen bad things happen when you don't mount the hard drives horizontally).
Coincidentally, someone on ncix website had a similar question and the consensus was that it didn't matter...something to do with "fluid dynamic bearings" (:censored: is a "fluid dynamic bearing" anyways?)
Sooo what is your opinions on longevity of vertical mounting hard drives?
I REALLY would like to get a p182 BUT not if it means replacing hard drives every year or two!
Thanks!
enaberif September 27, 2007 12:45 PM
Originally Posted by Johnboy (Post 20773)
Hi everyone,
Thanks!
makes no difference.
Rapid-X October 12, 2007 10:58 AM
wait a sec
depends if u put it vertivcallly it might skip. I know u guys are probally laughin but i had 4 drives in my case at once so i made a braket vetically to mount all the drives and i bumped the case one day by accident tryin to get a cd off the floor and my harddrive skipped which gave me a blue screen and shut my system down. it fired back up normal but im sure it was from that cause i tried it again and it did the same thing.
enaberif October 12, 2007 11:04 AM
Vertically or horizontally makes no difference.
Your hard drive skipped because you lacked vibration mounts and jerked your hard drive enough to cause this. I have done this on many computers and you'll have to reboot and pray.
It has nothing to do with the mount.
chibi_man October 12, 2007 12:28 PM
Agreed, makes no difference... I had my last machine set up with the drives vertical.
