Originally Posted by AkG Small read and write speeds are what will make or break how "fast" your system feels (BUT the other results DO matter and you cant just focus in on it and only it). The other important area for "system speed" is random access time.
If one has a lower random access, use THAT drive as your OS drive (IIRC Seagate usually is slightly worse than WD in this area....but it has been awhile since I looked at 'em).
If it is the same for both I'd go for the Black....but I truly doubt you will notice much dif. Its not like one is doing 10+mb/s 4k writes and the other 1mb/s. BUT higher sequential speed is more important for a "data" drive and this is where the Seagate appears to shine.
DL the seagate migration tool or WD version. BOTH are hobbled versions of Acronis. |
I absolutely love it when someone brings access time into the discussion, expecialy for a boot drive, because it is absolutly TRUE that access time IS more important than STR. O/S files are generally smaller, much larger in number, and a boatload of them must be read just to boot up. Even more must be read and/or written to when an application is used. Yet, after all these years, people continue to concentrate on STR as the most important characteristic. NOTHING could be further from the truth. The blacks would be my choice as well, if I were looking for a 7200 rpm drive. But, owning Velociraptors and SCSI drives now, I wouldn't touch anyone's 7200 rpm drive with a stolen 10 meter pole. Today's top of the line 7200 rpm drives can nearly match STR with SATA and SCSI, but nowhere near in access time. If you want access time without the SCSI pricetag, you have ONLY ONE choice and that is VelociRaptors. Expensive, yes, worth it, for most folks who buy them and get a feel for them YES. They won't let go of them either. But for more casual uses of home PC's top of the line 7200 rpm drives are find, and I'd have to chose the WD Black.
