-   -   answer this (http://www.hardwarecanucks.com/forum/storage/2700-answer.html)
Rapid-X September 25, 2007 03:20 PM
answer this
wierd but thinking about it if i copy everything off one sata drive and paste it to the otehr can i take out the first drive and run xp with all the programs and everthing installed on the new drive??
eg
western digital 200 gig primary rite now
maxtor 250 gig secondard drive
want to make it
Maxtor primary and sell the western digital
enaberif September 25, 2007 04:08 PM
eg
want to make it
Only way that'll work is if you "Ghost" it.
born2expire September 26, 2007 07:45 PM
id hold onto the WD and sell the maxtor before it goes down in flames like all maxtors.
Misoprostol September 27, 2007 11:23 AM
My Maxtor Diamondmax9's are still running just fine :s
JD September 27, 2007 07:33 PM
My 120GB Maxtor DiamondMax9 SATA died. Out of no-wheres too. One day I just got hit by a corrupted MFT file. Never got back all the files on it, lost a ton of pictures. Ended up having a whole bunch of bad sectors or "moved" sectors. That day sucked. It actually happened just when I was about to move everything off it onto my new 250GB WD hard drive. Funny how that worked out.
Anyways, keep the WD. I've had much better luck with them over Maxtors. But if you must switch, SeaTools/MaxBlast or something should do what you want for free.
