Old December 13, 2009, 10:57 PM
Evilyeti's Avatar
Default IDE 2.5" and 3.5" USB Docking Station?
Hey guys,
I just recently purchased a SATA 2.5"/3.5" USB docking station and the thing works great, I can't believe i never bothered to buy something like this earlier.
My first question was though, Does anybody make a IDE 2.5"/3.5" docking station? I only ask because i checked the usual spots, DirectCanada, NewEgg and NCIX and they only carry IDE 2.5 or 3.5 drive enclosures, they don't appear to carry an IDE 2.5"/3.5" docking station.
And my second question is, if nobody makes a 2.5"/3.5" IDE docking station, can you buy for example a 3.5" IDE hard drive enclosure and use it for both 2.5" IDE and 3.5" IDE or is the adapter different on both for the IDE connection? I do not plan on ever having the enclosure sealed / put together. I would just try to use it like a docking station.
Or what would be another option for me?
Thanks in advance
This is my signature! Roar
Old December 19, 2009, 03:44 PM
no_pulse's Avatar
As far as I know there is only SATA HD docking stations. However, there are adapters that will convert IDE or SATA to usb so you can transfer files from either IDE/SATA without having a external enclosure. You can also use it for DVD/CDroms as well.
Ultra makes one and tigerdirect.ca has it. Buy the Ultra USB 2.0 to IDE/SATA Cable Adapter at TigerDirect.ca
Originally Posted by kruzn4evr:
"The peppers fired a warning shot. Some were so loud and echoing that I was later told a few folks in
other aisles had ducked, fearing that someone was robbing the store and firing off a shotgun."
Old December 19, 2009, 03:48 PM
gingerbee's Avatar
I think there only sata ( one of the best buys i every did forget about enclosers they heat up way too much ah ah vantec crap ) not to point any fingers ha ha
[WTB] T61/W500 docking station elninio Buy/Sell & Trade 0 April 12, 2009 06:22 PM
[WTB] 2.5" laptop PATA/IDE HDD tallmike Buy/Sell & Trade 1 February 7, 2009 05:01 PM
3.5" USB Hard Drive Enclosure (IDE) tester3000 Buy/Sell & Trade 4 August 1, 2008 08:58 PM
FS / Lenvo/IBM Thinkpad Docking Station! $100 Cptn Vortex Buy/Sell & Trade 1 July 17, 2008 05:24 AM
"Girly" 2.5" IDE Enclosures encorp Storage 13 July 14, 2008 09:19 AM
