Old December 8, 2009, 09:47 AM
chrisk's Avatar
Folding Captain
I got a 120GB Vertex on Windows 7 and the SSD upgrade was the most substantial one I did in ages.
I flashed my firmware before installing Windows. I would recommend doing a fresh install after doing a firmware update as you will not have to worry about losing data, and Windows 7 will adjust the required settings for you and your drive will perform tip-top. Flashing was easy with the guides on the OCZ forums.
If you are installing Vista (or especially XP), you have more research to do, and folks like Squeetard and Lowfat would have much more detailed advice than I as they have been at the SSDs for ages.
Fold for team #54196
Old December 8, 2009, 09:48 AM
Oversized Rooster's Avatar
Originally Posted by Surk View Post
Only real concern i have is flashing the firmware.. Is it true each flash you do, you lose your OS ??
Of course not! You don't lose anything. I just flashed both my OCZ Vertex drives to 1.41 and booted back into Windows. To flash, you must temporarily place the chipset in IDE mode and flash each drive at a time when connected to the SATA0 port on your mobo.
Sanitary erase WILL destroy everything on your system but it restores the drive to like-new speeds.
Main: Intel 2600K @ 4.8GHz | Gigabyte P67A-UD7-B3 | 16GB Corsair DDR3-2000 | 2 x 240GB Corsair Force 3 in RAID1 | 2 x 4TB Hitachi 7K4000 | 3 x 2TB WD Caviar Black | 3WARE 9650SE | Antec 1200 | Seasonic XP-860 Platinum | 2GB GTX 670 | 2 x 27" Asus VE278Q | Auzentech Prelude | Win7 Pro 64-bit
Old December 8, 2009, 10:16 AM
gingerbee's Avatar
ok well first off vista is no problem at all all the same tweaks that have to be done to vista have to be done to 7 too so and vista does the alignment right so it is really only xp that you have to worry about
the best tweaks you can do Windows 7 - Ultimate SSD Speed Tweaks
and it works fro both vista/7 why do people think that 7 is so different then vista it's the same os without all the crap. fyi for you all
Old December 8, 2009, 10:43 AM
Varroa's Avatar
For most of the new firmwares you don't loose data but there are a few older firmwares that did delete all data when you flashed (usually the ones that still required to jumper to flash). With all the newer firmwares (1.30 and up or maybe even older) you can flash back and forth without problems. I have flashed from 1.4 (TRIM) to 1.41 (Garbage Collection) and back with no troubles.
GAMER: Win7 Pro x64, I7 3770 (stock) (CM 212+), Asus P8Z77-V Pro, XFX 6950 2GB, Corsair Vengeance LP 4 x 4GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Intel X25-M 160GB, 1TB WD Blk, DVD, BRD, HX750W, Auz X-Fi Prelude, Intel Pro CT Gbit NIC & CM Cosmos
Game Server: Win7 Pro x64, AMD Phenom II X4 960T Zosma, Gigabyte GA-MA770-UD3, 2x2GB Gskill DDRII 1000, 640GB WD Blk, 1 ODD, Asus 9600 GSO, Intel Pro PT Gbit, Corsair 400W PS & Antec 300.
Old December 8, 2009, 10:47 AM
gingerbee's Avatar
@varroa did you find that (Garbage Collection) worked or not?
Old December 8, 2009, 11:03 AM
Varroa's Avatar
Actually in my case, TRIM caused data corruption on my AGILITY drive. It had something to do with have two SSDs installed. I had to switch to GC and that solved my data corruption issues and it seems to work well. The only downfall to GC is it can shorten the life of your drive if you are a heavy write/erase/write/erase sort of user. GC will actually product better results than TRIM in terms of restoring lost write performance. TRIM also only works in single drive setups (no raid) and only with the microsoft storage drivers (ie, can't use AMD or INTEL drivers).
There is another way to restore performance called Tony Trim, just Google it or go to the OCZ forums (SSD generation 2 sub directory) to read more. I tried it and it works well but it is a labour intensive activity and not recommended on a day to day schedule.
Old December 8, 2009, 11:13 AM
I also am considering a Cheetah 15k SAS 148G SCSI drive with an Adaptec\Promise card..price-wise almost same cost as a SSD ..Any thoughts on this or will the Cheetah not perform noticably faster on desktop apps ( PS-DW CS4--Lightroom ) then my V-Raptor 150G
Old December 8, 2009, 11:17 AM
Varroa's Avatar
I moved from a 150GB raptor to the 30GB vertex and it is like night and day the difference! The only thing 10,000RPM drives have over conventional 7200RPM drives is seek time (a 2TB black drives beats any Raptor except on seek time) but a SSD will blow a raptor out of the water. Maybe a couple of Cheetahs in RAID 0 will come close to a SSD but a couple of SSDs in RAID 0 will saturate the bus!
  #19 (permalink)
Old December 8, 2009, 11:22 AM
lowfat's Avatar
[QUOTE=Varroa;298799]I moved from a 150GB raptor to the 30GB vertex and it is like night and day the difference! The only thing 10,000RPM drives have over conventional 7200RPM drives is seek time (a 2TB black drives beats any Raptor except on seek time) but a SSD will blow a raptor out of the water. Maybe a couple of Cheetahs in RAID 0 will come close to a SSD but a couple of SSDs in RAID 0 will saturate the bus![/QUOTE]
No. RAIDed mechanical drives will never come close to SSD's in most tasks. Random access time is just way too high.
  #20 (permalink)
Old December 8, 2009, 11:27 AM
Varroa's Avatar
[QUOTE=lowfat;298800]
That is why I said MAYBE a COUPLE may come CLOSE.
I still think a SSD is the way to go if you are going to be spending the money.
OCZ Vertex 120GB SSD Review Comment Thread AkG Storage 5 July 18, 2009 10:39 AM
[FS] OCZ Vertex 30GB SSD quikgp Buy/Sell & Trade 8 July 2, 2009 06:35 AM
OCZ Technology Announces Vertex EX 2.5” SLC-based SSD MAC Press Releases & Tech News 13 April 24, 2009 04:40 PM
