Old December 2, 2009, 09:21 PM
Phaddie's Avatar
Default Caviar Black 2TB question
Hey Guys..
In the review on this site of the 2TB caviar black the reviewer states that installing the OS in a 200gb partition would increase the speed. Can someone explain to me exactly how and why this would happen?
Also, I just bought one of these drives and will be using it in a new system. It has been years since I have built a non raid system and I am not sure if I remember how to partition a single HDD. Can someone refresh my memory. I will be installing Win7 Ultimate 64bit. My Mainboard is an ASUS p5q-e if that matters..
Thank you in advance
Phad
ASUS P8-Z68-v PRO, INTEL 2600K @ 4.4 ghz, ZOTAC GTX-580, Lian Li Armour Suit PC-P80, OCZ GamerXStream 700W, Nuctua NH-D14, MUSHKIN 996995, 2TB Caviar Black, 1TB Caviar Black, 120GB Vertex 3, SAMSUNG 245T
Old December 2, 2009, 09:27 PM
MarkOne's Avatar
very simple. if you use the first 200 gb, the zone where the oS will be install is at the outside edge of the plater .. it's where the disk get the more inches per seconds in speed.
Old December 2, 2009, 09:29 PM
Phaddie's Avatar
Yip that is pretty simple. Thanx.. Also can you refresh my tired bain about how to go about creating this partition? Is Fdisk still a thing that is used? And woudl I do that from the Win7 install CD?
Thanx in advance..
Old December 3, 2009, 12:17 AM
ipaine's Avatar
Just use your Windows 7 disk to set up the partition. When you go to install it you will get an option to pick the drive. Just choose the advanced option and then you will have other options appear and you can then just make a partition the size you need. (Hope that makes sense, need sleep)
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old December 3, 2009, 07:13 AM
Phaddie's Avatar
Cool... Thanx Guys!!!
I do have another question. This computer currently has a RAID 0 array in it. Is it possible to assign this array to be secondary to the new drive so that I can see the data on it? This will save me having to back up the data to move it to the new drive..
Phad
Western Digital Caviar Black 2TB Hard Drive Review Comment Thread SKYMTL Storage 25 January 5, 2011 05:17 PM
Western Digital to Release 2TB Caviar Black & Enterprise Class Drives FiXT Press Releases & Tech News 0 September 1, 2009 11:03 AM
WD Caviar Black 640gb Jonwall Storage 27 May 16, 2009 06:28 PM
