Old November 28, 2009, 03:25 PM
Jack Rabbit's Avatar
heh... It's all about risk management. There is always a safer solution. The question is, "is it worth the time and expense".
At least you did not lose anything but some time.
- James Graham
Old November 28, 2009, 09:14 PM
lowfat's Avatar
Originally Posted by b1lk1 View Post
Running RAID without a dedicated PCI/PCI-E controller that has it's own processor and memory is garbage anyways. Motherboard RAID is slow on its best days.
For RAID0 the difference is very minimal. At least for mechanical drives.
Mael
Big Lian Li
Forever Alone
Old November 28, 2009, 09:47 PM
MarkOne's Avatar
thanks to have underline it
for 0 raid my approval was only on that part of the reply :
Running RAID without a dedicated PCI/PCI-E controller .... is garbage anyways. ..
My problem will not have happen on a high-point card, because I will have fix the problem in the bios menu. it was the lack of option in the Intel one , that give me trouble
raid processors are at best for raid 5 , for raid 0 , Lowfat is right.. it's make so few difference
raid 51? bissa Storage 2 September 15, 2009 07:06 PM
Help with Raid 0 JerryZ Storage 1 August 10, 2009 08:15 AM
Help with RAID 1 Jackquelegs Storage 2 May 30, 2009 12:44 PM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
raid help Jhayman Troubleshooting 9 November 8, 2007 02:10 PM
