-   -   WD Caviar Black 640GB'ers in Raid 0 (http://www.hardwarecanucks.com/forum/storage/25826-wd-caviar-black-640gbers-raid-0-a.html)
Killswitch November 23, 2009 09:13 PM
Just a few seconds ago I ordered two WD Caviar Black 640GB'ers for a Raid 0 config that will replace my 150GB Raptor. :thumb: (I really want a SSD but they're too damn expensive! :blarg:)
Now, I know I'll see a good increase in boot-up, game loading, and large file tranfer times..... but how much more speed should I expect to see over the Raptor? I've been trying to find some good solid info in other forums but too many people have different opinions. I'm assuming that the ones who didn't see any benefits running Raid 0 didn't have a decent setup or just didn't do it properly. I'll be using the raid controller on the mobo in my specs.
Does anyone here running Raid 0 have any tips for me regarding performance tweaks?
I read that short-stroking the hard drives will help with random access times. Does it really make a big difference? I don't need 1.3TB of space in my PC so short-stroking won't bother me. I'll likely end up trying it anyway just to see. I also read that stripe size is critical for speed performance. Any input on that one?
Thanks in advance guys! :canadianwave:
Supergrover November 23, 2009 09:24 PM
I haven't run Raptors or Blacks in a raid but short stroking my 500's netted me a little boost, from 180MBs avg to 205-210MBs avg, my access avg stayed pretty much the same as just partition rather than short stroked.
bojangles November 23, 2009 09:26 PM
I don't know what kind of RAID architecture AMD uses on their board, but you basically just answered your own question: it will perform faster than that ANCIENT Raptor that you have. MUCH FASTER.
Short stroking will keep speeds more constant because it will only use the outer sectors of the disk. Use at your own risk.
Killswitch November 25, 2009 03:19 PM
Is there a sweet spot when short-stroking a drive, or will it just be a "try it and see" process? Some say to use 20% of each drive.
I know it will perform faster, that's obvious. What I was asking is if anyone could tell me HOW MUCH FASTER so that I'll know what to expect once the raid setup is running. BTW, what do you mean by "use at your own risk"?
miggs78 November 25, 2009 03:46 PM
Welcome to the club kill.. I got a 640gbx2 RAID going on, just got myself a WD 1TB Black for storage.. SSD's are really expensive, and the ones that are cheap the Idlinx ones aren't any good..
You'll see some difference for sure.. Although curious myself too why bojang said "use at own risk"..
Killswitch November 25, 2009 04:02 PM
Hey Miggs, did you short stroke your 640's? If so what size did you find worked best? Also what kind of numbers do you get from HDTune (if you've ever ran it)?
bojangles November 25, 2009 04:34 PM
I said use at own risk because I've never done it before, so I don't know the risks...I should have said that before lol. My bad. There probably aren't any though lol.
Killswitch November 25, 2009 04:56 PM
Well one risk that I do know of is that there is twice the risk of losing your data if one of the drives happen to shit the bed. I never store any files of value on my rig anyhow........ but besides, WD makes reliable hdd's.
headsh0t November 25, 2009 04:57 PM
Just so you know it's impossible to make them all %100 reliable.
Killswitch November 25, 2009 05:40 PM
Really? I thought Maxtor did. :rofl:
Seriously though, I know that it's impossible to make them all %100 reliable. The same goes for practically anything you buy.
