  #41 (permalink)
Old December 24, 2009, 10:34 PM
lowfat's Avatar
Some Demuxing results:
Obviously the ioXtreme has serious IOPS if using the X25-M as a source only benefited a 5% increase in demux time. And when demuxing from the X25-M to the X25-M the machine was unusable due to stuttering.
And the proof
from X25-M G1 to ioXtreme
PHP Code:
eac3to v3.17
command line
"C:\Program Files (x86)\eac3to 317\eac3to.exe" "C:\The Hurt Locker\" 1) 2: "D:\The Hurt Locker.mkv" 1: "D:\The Hurt Locker.chapters.txt"
M2TS, 1 video track, 2 audio tracks, 1 subtitle track, 2:11:06, 24p /1.001
1: Chapters, 15 chapters
2: VC-1, 1080p24 /1.001 (16:9)
3: DTS Master Audio, German, 5.1 channels, 16 bits, 48khz
   (core: DTS, 5.1 channels, 16 bits, 1509kbps, 48khz)
4: DTS Master Audio, English, 5.1 channels, 16 bits, 48khz
5: Subtitle (PGS), German
Creating file "
D:\The Hurt Locker.chapters.txt"...
[v02] Extracting video track number 2...
[v02] Muxing video to Matroska...
Added fps value (24 /1.001) to MKV header.
Video track 2 contains 188592 frames.
eac3to processing took 1 minute, 48 seconds.
Done.
From ioXtreme to ioXtreme
PHP Code:
eac3to v3.17
command line
"C:\Program Files (x86)\eac3to 317\eac3to.exe" "D:\The Hurt Locker\" 1) 2: "D:\The Hurt Locker.mkv" 1: "D:\The Hurt Locker.chapters.txt"
Creating file "
eac3to processing took 1 minute, 54 seconds.
Done.
from X25-M G1 to X25-M G1
PHP Code:
eac3to v3.17
command line
"C:\Program Files (x86)\eac3to 317\eac3to.exe" "C:\The Hurt Locker\" 1) 2: "C:\Users\Brendon\Desktop\The Hurt Locker.mkv" 1: "C:\Users\Brendon\Desktop\The Hurt Locker.chapters.txt"
Creating file "
C:\Users\Brendon\Desktop\The Hurt Locker.chapters.txt"...
eac3to processing took 6 minutes, 50 seconds.
Done.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #42 (permalink)
Old December 24, 2009, 11:08 PM
lowfat's Avatar
PHP Code:
mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
D:\The Hurt Locker.flac': Using the FLAC demultiplexer.
+-> Parsing the FLAC file. This can take a LONG time.
+-> Pre-parsing FLAC file: 0%
+-> Pre-parsing FLAC file: 5%
+-> Pre-parsing FLAC file: 10%
+-> Pre-parsing FLAC file: 15%
+-> Pre-parsing FLAC file: 20%
+-> Pre-parsing FLAC file: 25%
+-> Pre-parsing FLAC file: 30%
+-> Pre-parsing FLAC file: 35%
+-> Pre-parsing FLAC file: 40%
+-> Pre-parsing FLAC file: 45%
+-> Pre-parsing FLAC file: 50%
+-> Pre-parsing FLAC file: 55%
+-> Pre-parsing FLAC file: 60%
+-> Pre-parsing FLAC file: 65%
+-> Pre-parsing FLAC file: 70%
+-> Pre-parsing FLAC file: 75%
+-> Pre-parsing FLAC file: 80%
+-> Pre-parsing FLAC file: 85%
+-> Pre-parsing FLAC file: 90%
+-> Pre-parsing FLAC file: 95%
+-> Pre-parsing FLAC file: 100%
D:\The Hurt Locker.mkv': Using the Matroska demultiplexer.
D:\The Hurt Locker.flac' track 0: Using the FLAC output module.
D:\The Hurt Locker.mkv' track 1: Using the video output module.
The file '
D:\The Hurt Locker.bluray.1080p.flac.mkv' has been opened for writing.
The cue entries (the index) are being written...
Muxing took 136 seconds.
From the ioXtreme to the ioXtreme. 17.2GB movie in 136 seconds is pretty decent
Queen of Dreams WIP
Big Lian Li
Complete
  #43 (permalink)
Old December 25, 2009, 07:49 AM
gingerbee's Avatar
thank lowfat for the numbers not bad at all. not as good as i thought ( maybe an ioextreme to another ioextreme ha ha ) great movie by the way
  #44 (permalink)
Old December 29, 2009, 05:28 PM
p3t3rson's Avatar
The ioXtreme is capable of much greater performance than seen here so thoroughly by lowfat. The ioXtreme is being bottle necked by the fact that the OS is still on a standard SSD, as the OS is still involved in the opening and running of any software, the software code (server or enterprise software will fly on this card), and CPU limitations.
  #45 (permalink)
Old December 29, 2009, 05:46 PM
MarkOne's Avatar
Can those IoXtreme can boot if the system partition is on the regular SSD and the boot ( windows ) partition on the Io ?
  #46 (permalink)
Old December 29, 2009, 06:05 PM
p3t3rson's Avatar
The OS must be in the system patition. So to answer your question, no.
There is a firmware in the works to make the ioXtreme bootable, giving greater performance.
  #47 (permalink)
Old December 29, 2009, 06:12 PM
MarkOne's Avatar
no way the OS is in the boot partition
  #48 (permalink)
Old December 29, 2009, 06:23 PM
p3t3rson's Avatar
I was not referring to the system reserve if that's what you meant
  #49 (permalink)
Old December 29, 2009, 06:28 PM
MarkOne's Avatar
don't try to turn around , the C; is in the boot partition not in the system partition , at least in 7 ( where in the frame of the c; partition you see the word system )
you can see under reserve ; the system,.... partition
and under C: boot,...partition
it's pure NTFS basic knowledge
the system partition is where is located the files the system need to boot the Os ( in the case of 7 , it's also the reserved partition )
the Boot partition is where is located the Windows , in older system like XP, the boot and the system was more than often in the same partition, but not always
  #50 (permalink)
Old December 29, 2009, 07:26 PM
p3t3rson's Avatar
First off I am not trying to turn anything around. IDK maybe I am just misunderstanding the question or poor choice of words answering it.
As far as I am aware Windows 7 creates that hidden partition to store system files and bootable files that are required to boot your computer in recovery mode. You can actually install Win7 without it. Here is a link describing how to do it:
How to Prevent Windows 7 from Creating a Hidden /Recovery /System Reserved Partition during Installation
The reason the ioXtreme can't be booted from is that currently Win7 can only natively boot from and IDE or sata. So until a firmware is released more or less tricking the OS to think its on a sata/ide drive or until Win7 is update to run natively on a PCI-e SSD its not bootable. It has nothing to do with the System Reserve partition
