Old November 16, 2009, 11:47 AM
Default Quetion regarding memory overclock/data corruption
So I overclocked my ram today and it passed 10 passes of memtest and also successfully ran few loops of 3dmark vantage and 3dmark06 in windows without crashing or bluescreen so I concluded it's all stable and good.
But as soon as I shutdown my computer and rebooted afterwards, I was granted by annoying "Checking your C drive NTFS This file need to check for consistency and is recommend that you check it or you can skip it" message.
So why do you guys think this happened? I mean I know the cause of the problem is ram which I have overclocked beyond it's capability, but then why did it pass 10 passes of memtest? From my understanding memtest is far more reliable tool than this or is it not? Or is there any problem elsewhere?
Btw cpu is stress tested with both linpack and intelburn(1hour&20pass). Memory is rated at 1066 but I overclocked them at 1080.(changed multiplier from 1:1 to 4:5) I knew corrupted hard drive has had 17 bad sectors in it but it's not counting up anymore and it has never caused problem like this before, and as soon as I remove memory overlclock message went away anyway so I don't really think that's the cause either. (new drive on it's way though)
So could someone guess and explain what has likely happened to my system by reading this? At the moment I'm at a loss to be honest.
This is what my sytem spec's like, thanks.
Core2Quad Q9550E0 3.83G TRUE
Gigabyte EP45-UD3R
Zotac GTX 280 1GB
4GB G.Skill DDR2 PC2-8500PK
SoundBlaster X-FI XtremeMusic
Corsair TX 750W
Old November 23, 2009, 07:50 PM
0o0 0o0 is offline
I honestly wouldn't worry too much about it, just make sure you back up important data and photos etc. My dad's P4 used to do that, passed an hour of OCCT, but bsod after a few days of use... I've got the feeling that it's not to do with the cpu stability, maybe something like the stability of some chip on the mobo or something... maybe the southbridge/sata controllers aren't stable. Don't take my word for it though, just a consideration lol
Old November 27, 2009, 12:30 AM
Thanks for your reply 0o0, it was simply a drive failure it seems, ever since I installed my new WD drive I have not experienced any data corruptions anymore. I have now successfully clocked my ram and a new drive added some extra performance to my system so I'm really happy now:)
A-DATA Unviels XPG Plus DDR3-2200+ Memory Claimed as Fastest In the Industry FiXT Press Releases & Tech News 4 August 2, 2009 04:23 AM
A-Data Announces New 4GB Single Module DDR3 Memory In All Lines FiXT Press Releases & Tech News 2 July 28, 2009 01:12 PM
[FS] A-data Vitesta DDR2 800 CL4 memory 4GB nakano2k1 Buy/Sell & Trade 5 February 21, 2009 10:43 AM
OCZ Memory owners: Try your memory at lower Volts sswilson RAM 0 October 24, 2008 07:36 AM
Constant BSOD, data corruption garyoa1 Troubleshooting 22 August 18, 2008 03:30 PM
