Old October 26, 2009, 03:58 PM
Randyman's Avatar
Default External Hard Drive
Can any of you folks suggest a good External Hard Drive I don't emagine I'll need more than 1Tb.
Should I go with Sata or USB?
I'm running xp 32bit and will have to back everything up so I can do a clean install with Win 7 64bit.
Thank you.
Old October 26, 2009, 04:01 PM
Supergrover's Avatar
I would grab a Vantec encloser and 1tb WD. Green or blue for storage, Black if your going to be using it everyday.
Go E-Sata way faster and supports AHCI/RAID
R.I.P.
Old October 26, 2009, 04:03 PM
Perineum's Avatar
Supergrover said it all.
Old October 26, 2009, 04:33 PM
Randyman's Avatar
Will this work?
Vantec Nexstar 3 Black Aluminum 3.5IN SATA Hard Drive Enclosure eSATA USB2.0 Firewire IEEE1394
Actual product may not be exactly as shown.
<A href="http://ncix.com/go/?expressshipping" target=_blank>
Reg. Price:$63.21 CA
Western Digital WD1001FALS Caviar Black 1TB SATA2 7200RPM 4.2MS 32MB 3.5IN Dual Proc Hard Drive OEM (WD1001FALS)
$10.00 Instant Rebate! Special price of $119.97 AFTER Instant Rebate (expires 10/27/09). Instant rebates are limited in quantity and may change without prior notice.
216 Customer Reviews
Sorry I'm not sure which WD drive to use.
Do I have to Connect this to the motherboard first to format it or is there software with the enclosure?
Old October 26, 2009, 04:56 PM
That enclosure is fine.
What will be the use of the drive? Just Backups and storage?
R.I.P.
Old October 26, 2009, 04:58 PM
Randyman's Avatar
yes as far I know for now. Is this overkill?
Old October 26, 2009, 04:59 PM
Better price on that enclosure.:
Vantec Nexstar 3 Black Aluminum 3.5IN SATA Hard Drive Enclosure eSATA USB2.0 Firewire IEEE1394 - DirectCanada
R.I.P.
Old October 26, 2009, 05:01 PM
Originally Posted by Randyman View Post
yes. Is that overkill?
If it is just backups then yes a black is over kill, grab Something like this:
NCIX.com - Buy Western Digital WD10EADS Caviar Green 1TB SATA 32MB Cache 3.5IN Hard Drive OEM - WD10EADS In Canada.
R.I.P.
Old October 26, 2009, 05:05 PM
Randyman's Avatar
Great. Thanks for your help. Man you folks are the best.
FS: A.C. Ryan AluBoxDuo External Hard Drive Enclosure cyberspyder Buy/Sell & Trade 12 December 27, 2009 10:36 AM
Can you install operating system to external hard drive. JORD4N O/S's, Drivers & General Software 5 September 22, 2009 07:26 PM
External Hard Drive JD Storage 15 September 5, 2008 03:25 PM
Seagate FreeAgent Pro 1TB External Hard Drive Jon_di2 Computer & Electronics Hot Deals 9 July 23, 2008 05:08 AM
Good cheap external hard drive. belgolas Storage 9 May 20, 2008 10:48 PM
