Old September 28, 2009, 09:08 PM
Default BIOHD-8 Error (Hard Drive)
alright so yesterday I switched computer cased. 1st I got a System fan failure error. Fixed that.
Now I try to start up my computer, and when it gets to the XP loading screen, it just restarts.
I ran a diagnostic on it and it came up with a Hard drive error of "BIOHD-8"
Can anyone help me? What does the error mean? How do I fix it? ? :(
Old September 28, 2009, 09:09 PM
Set or check your BIOS to see if the SATA is set to RAID
Old September 28, 2009, 09:35 PM
Caldezar's Avatar
Check your other thread on the same subject, posted a couple suggestions. No need to have a second thread going. We'll see the thread, even if it's under 'air cooling'. And if you really want it moved to a new area, a moderator can likely do that for you.
HD Failure?? Hard REboot during error checking mattydies Troubleshooting 3 August 26, 2009 05:50 PM
Can't Format Hard Drive AmuseMe Troubleshooting 6 August 20, 2009 11:57 PM
rebuilding my hard drive tzetsin Troubleshooting 17 June 20, 2009 05:46 PM
Best way to copy one hard drive to another? chouchou Guides & How-to's 10 May 15, 2009 09:17 PM
Hard drive WolfBane Storage 8 July 24, 2008 12:08 PM
