-   -   Question on Raid 1 (http://www.hardwarecanucks.com/forum/storage/23434-question-raid-1-a.html)
Bojamijams September 22, 2009 08:49 AM
Question on Raid 1
If I have two hard drives (same ones) and one is empty and the other is filled with data, then when I want to make them a Raid 1 setup, will it automatically copy the data from the filled one to the empty one, or do they both need to be empty when I set them up as Raid 1?
gingerbee September 22, 2009 09:40 AM
no it will erase the data and start coping the data from that point on to both drives
Bojamijams September 22, 2009 11:09 AM
Thank you :)
Finally, is there any point in finding the right stripe size as you have to do on a Raid 0 or does that not matter with Raid 1?
gingerbee September 22, 2009 11:11 AM
I don't think it matter that much on raid1 i don't know for sure i don't run it that often. But i have always found that 128k or 64 strip always gives pretty good performance:thumb:
Bojamijams September 22, 2009 02:13 PM
Thanks again :)
bushwhacker September 22, 2009 11:50 PM
RAID 1 arrays can be built as you choose
Originally Posted by Bojamijams (Post 259265)
If I have two hard drives (same ones) and one is empty and the other is filled with data, then when I want to make them a Raid 1 setup, will it automatically copy the data from the filled one to the empty one[...]
not automatically - but if you choose to build a RAID 1 array by adding a second HDD to match an existing HDD (w. data) then that is how the array is built. From that point on data is written to both drives to keep them functioning properly in the RAID1 config.
gingerbee September 23, 2009 06:08 AM
he's right i think at the os level you can install a second hard drive that's the same and see through the intel storage manager software about building a a raid1 array from there ( sorry I never use raid1 at all )
Bojamijams September 23, 2009 06:22 PM
So the data on the first one wouldn't be deleted? It just wouldn't be mirrored either?
gingerbee September 23, 2009 06:32 PM
^ see that's where i am not sure if when it builds the raid1 within the OS if it copys all data that's on the 1 hd to the 2nd hd ( I don't use raid1 and when i do it's from the hardware level )
Bojamijams September 24, 2009 11:59 AM
Well just to be safe, I"ll move the data onto an external drive, format them both, build a Raid 1 and put it back on .. little extra work, but leaves out the guessing :)
