Old May 19, 2011, 04:10 PM
Upgrade your chipset and storage drivers from Gigabyte's web site and try again with Data Lifeguard. That looks a lot more like driver issues than disk issues. If it was really that bad the short test would fail immediately. You can also try Intel Desktop Utilities if your motherboard is supported.
If you're comfortable with Linux you could use smartmontools with the following line:
Code:
smartctl --all /dev/sdX
Where X is a letter of the alphabet corresponding to your drive (e.g. sda for the first drive, sdb for the second...)
C0000218 Fix "long and short" TopDogZero O/S's, Drivers & General Software 0 May 28, 2008 11:20 AM
