Transferring Mirrored Disks I just built my new rig and I'm trying to move all the data over. In my old rig I had 2x 500GB mirrored drives and I was wondering what the best way to transfer the data (and drives) over to the new computer. 1) Can I take out one drive, place it in the new computer, back up the information and then bring the second drive over and setup the raid? 2) Do I need to back up the information, move both disks over and reformat? Whats the best way to do this? |
Depending how much data you have on the drives, I would make an image backup if you have the space. Just in case. Then swap one drive in, and make sure the data is there. |
And it works even if the motherboard is different? The RAID software doesn't make it impossible to read on another computer? |
I use Acronis and backup all data to a external drive, format & install new drives, then put all backed up data into a folder on new drive. I then pick through what I want to keep and delete the rest. Not sure if it is the best way but it works. |
Shouldn't be an issue - I regularly swap my pair of 500's in RAID 0 between motherboards when I want to access data on them. As long as the new motherboard is set to RAID, it's hassle-free. |
agreed MpG Raid data that is stamped onto a hard drive is mostly universal. You should be able to do a direct swap and the new mobo will recognize it as being a RAID 1 in good health. |
| All times are GMT -7. The time now is 01:33 PM. |
