Old September 2, 2009, 07:38 AM
gingerbee's Avatar
Default A-Data s592 question
Ok well i have been hunting online for anything and everything about the s592 i can find but what i can't find is if the wiper.exe works or not? any help or info thank in advance for anything guys/gals
Old September 2, 2009, 07:44 AM
"Quote This..."
Wiper.exe is proprietary software from ocz. I doubt it works on the adata.
Old September 2, 2009, 07:55 AM
gingerbee's Avatar
it seems to work on all indilinx ssd's that why i ask ( it's indilinx software not ocz ) and it's the same wiper for all the indilinx ssd torqx,vertex,supertalent and adata i hope we will see and it's fw 1.3 so jumper need for upgrades if possible not counting on the updates to the firmware though just hoping wiper works
Old September 2, 2009, 07:56 AM
"Quote This..."
Give it a shot, the first thing it does is search for and detect your drives, then it asks you which one to wipe. If it does not find any compatible drives it won't execute.
Old September 2, 2009, 07:59 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
We will have a review of it up shortly.
However, let me counsel you on something: hold off buying the drive until you see the review.
The S592 IS NOT firmware updateable.
gingerbee's Avatar
thank for the info i did not know that
Old September 2, 2009, 08:00 AM
gingerbee's Avatar
you might want to read i sig
gingerbee's Avatar
no firmware fine just hoping for the wiper plan on buying some vertex soon anyway
Old September 2, 2009, 08:03 AM
SKYMTL's Avatar
I was under the impression that the wiper.exe only works with certain firmwares...
Old September 2, 2009, 08:07 AM
gingerbee's Avatar
yes 1.3 or 1.2 and higher adn the s592's come with fw 1.3 ( kinda hoping akg's review will be up soon because i believe he would have checked this all is good though they run fast as hell still just think of the future thank guys )
A-Data s592 raid performance gingerbee Storage 22 June 18, 2010 02:44 PM
Data Recovery misterd Storage 1 January 13, 2009 12:08 PM
A-Data RAM zlojack RAM 11 December 7, 2008 03:22 PM
Data Recovery appplejack Troubleshooting 8 December 1, 2008 06:19 PM
