Old August 14, 2009, 04:56 AM
Default HardDrive plugged into JMicron or not?
I just completed my first build and noticed the JMicron slots so i plugged my sata 3.5" seagate in to see if it makes a difference and it does for me. I feel that its making my hard drive slow. Do i need a driver? Should i just plug back into the regular sata slots? What the benefits of this jmicron? This is my first post so i will take this time to say HELLO to everybody and thanks for help me (n00b) out. Coolsite by the way. The reviews are impecable. The depth that goes into it is astonishing!
Old August 14, 2009, 05:04 AM
misterd's Avatar
Typically the jmicron sata ports are slower then the ones built into the north bridge. What kind of motherboard are you using?
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
Old August 14, 2009, 05:13 AM
I am using the Asus P6T. What is a north Bridge? I see i have 6 sata slots total, 4 of which are horizontaly place and 2 which normal(90degrees) to the board. Are certain slots better than others?
Old August 14, 2009, 05:21 AM
CMetaphor's Avatar
Quadfather
I think he meant the southbridge . Probably an ICH10R since it's an x58 board. The Southbridge controls things like USB/Sata/1394/etc
Here's a zoomed view of your motherboard P6T):
http://usa.asus.com/prog_content/mid...spx?model=2731
The southbridge is under the smaller blue heatsink towards the bottom left in this picture. Your northbridge is actually under the larger heatsink with the "Asus" logo on it.
Using the sata ports that are built in to the southbridge will normally give you less latency, but it varies from controller to controller depending on what kind of interconnect there is between the southbridge and the sata controller (jmicron in this case). For example, a sata controller that connects to the southbridge via the PCI bus will be slow and not very useful at all, whereas one that connects via a pci-express 8x lane will be much much faster.
Old August 14, 2009, 05:24 AM
misterd's Avatar
Yeah what he said. Too early, not enough caffeine.
Old August 14, 2009, 05:28 AM
CMetaphor's Avatar
Quadfather
You're forgiven sir.
Old August 14, 2009, 05:34 AM
Cool, so ill plug back into the serial ATA instead. So on that zoomed picture of my board, are those 2 veritcaly placed sata slots better then the other 4? I just want to make sure i am getting the fastest speed possible.
Old August 14, 2009, 05:48 AM
CMetaphor's Avatar
Quadfather
According to the Asus specifications all 6 of those (the 4x at 90 degress and the two vertical ones) are all running off the southbridge and therefore should have no difference in performance. To be honest, I'm not even sure where the jmicron controller is, unless it is Only used for the eSata on the back IO of the board. Sorry, not familiar with x58s, hehe.
Old August 14, 2009, 07:19 AM
What is the controller? The JMicron slots?
Old August 14, 2009, 08:13 AM
misterd's Avatar
It could also be for the IDE interface on those boards.. I think.
Harddrive in Bios tom555 Troubleshooting 1 August 5, 2009 12:21 PM
[WTB] 30-60gb SSD, must have non-Jmicron controller Jackquelegs Buy/Sell & Trade 2 June 15, 2009 06:41 PM
harddrive failing. help please kyle_L Troubleshooting 2 May 10, 2009 06:44 PM
[WTB] laptop harddrive Rapid-X Buy/Sell & Trade 0 May 2, 2009 08:22 AM
need laptop harddrive Rapid-X Buy/Sell & Trade 3 February 14, 2008 12:46 PM
