Old August 10, 2009, 07:59 PM
sswilson's Avatar
Default External burner?
Anybody out there have much experience with external DVD burners?
Just picked up a netbook, and there's no way I'm going to go without backing up the OS onto a DVD.
Anything I should look out for, or do most of the available models offer much the same functionality?
I was looking at this one, mostly due to the lack of requirement for an AC adapter......
NCIX.com - Buy Samsung External Slim 8X DVD Writer USB 2.0 Blue - SE-S084B/RSLN In Canada.
Old August 10, 2009, 08:47 PM
bissa's Avatar
The one you linked is a good external, I had my laptops DVD drive die about 4 months ago so I picked this up and it has worked very well since, I can burn a full DVD in about 20 minutes.
Strong like hummingbird, swift like oak.
I'm sorry july, I couldn't see you behind all that feruary.
Old August 10, 2009, 09:01 PM
sswilson's Avatar
Thanks for the info. So far it's looking like my best option.
How does it get power? Is there a second USB connection?
Old August 10, 2009, 09:05 PM
geokilla's Avatar
Hm, not sure what you mean by backing up the OS onto a DVD. If what I think is what you're talking about, just use a program like Acronis or Norton Ghost and create an image file.
You can also install Windows 7 by using a USB. How To Install Windows 7 from a USB Flash Drive - Install Windows 7 from a USB Key - Legit Reviews
Old August 10, 2009, 09:06 PM
bissa's Avatar
Thrugh the USB, one plug is enough to read but sometimes it will fail while burning without 2 plugs I beleive it came with a dual plug cable (I bought a USB powered external HDD at the same time so I dont know which I got the cable from).
EDIT:
by using a program like acronis or ghost and burning images to a file and getting the program to verify the data, it is much harder to corrupt the data on a DVD that is in a case not being used than a HDD that may fail from general usage for accessing other files.
Old August 10, 2009, 09:12 PM
sswilson's Avatar
Just like any other laptop or pre-built, this has the option to back up the original media in order to restore it back to factory defaults if the hdd fails. Installing Windows 7 by USB key would defeat the entire purpose of this unit as I purchased it specifically as a Vista reference for work..... ;)
Old August 11, 2009, 07:15 AM
3.0charlie's Avatar
Went through a few externals, that would error out while burning. All had no AC power.
Then I bought this one, on special at the time for 40$: Future Shop: Computer Add-Ons: DVD & Blu-ray Drives: LG 20X Super Multi External DVD Rewriter (GE20)
No problems ever since. AC power rules.
Hydro-Quebec is salivating...
Old August 11, 2009, 12:59 PM
sswilson's Avatar
Thanks for the info. Since the main use is a low-end netbook, I was already a bit concerned about the power available through the USB bus. Your post put the icing on that concern.
Just pulled the pin on a different (AC powered) external Samsung, and a single stick of 2G PC2 5300.... :)
Old August 11, 2009, 01:11 PM
3.0charlie's Avatar
My pleasure.
It's my goto burner when I need to backup a customer's data when I get THE call...
Old August 11, 2009, 01:14 PM
Jon_di2's Avatar
I own this one (I think its the same model) , I remember someone was selling one on here a while ago too. Got mine for $49 at futureshop about a year ago. I'd reccomend it, no problems with it since I bought it over a year ago.
I had an external dvd burner before it that I had to hit on the top to get it going sometimes . It was some no name grey one... not recommended.
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
[WTB] chord for dvd burner cmac79 Buy/Sell & Trade 7 January 30, 2009 10:13 AM
cheapest dvd burner? CTA Storage 12 November 22, 2008 07:47 PM
external dvd burner for mac? elninio Mobile Computing 3 November 15, 2008 09:38 PM
LaCie Intros 4x Blu-ray External Burner Hardware Canucks Press Releases & Tech News 0 May 28, 2008 11:25 AM
Dvd Burner Mulder Storage 4 April 25, 2008 06:18 PM
