Old August 10, 2009, 12:23 PM
shayan288's Avatar
Default Hard Drive Formatting Question
Hi all,
I recently installed Partition Wizard because in about 3 days I will be installing Windows 7 Ultimate 64bit and be getting rid of my w7 Ult RC. There is an option in the program that says "format" and I would liek to format my C drive which is the drive im booting off of right now. If I select Format to C drive, does that mean eventually during the format my computer will jsut liek shut off or something? Is it possible to complete the format if that happens? Im kinda puzzled here. The reason why I dont want to just like pop the new windows 7 disk in and install it and replace my current version is because it leaves a "windows old" folder than I cant seem to delete and I just have way to many windows old folders now. Please help.
s288
The 288
Q9550 E0 stepping @ 4Ghz
Gigabyte EP45 UD3P
G.Skill pc2 8500 1066mhz RAM
Western Digital 250gb
Antec 1200
XFX HD5970
Steelseries Xai Laser Mouse
Windows 7 Ultimate x64
Old August 10, 2009, 12:43 PM
JimboToronto's Avatar
Do you have an old WinXP CD kicking around?
If so, boot from it and delete the partition.
Old August 10, 2009, 01:34 PM
shayan288's Avatar
aww man... I have to do that? There isnt any other way?
The 288
Gigabyte EP45 UD3P
Antec 1200
XFX HD5970
Old August 10, 2009, 02:56 PM
I thought you wanted to start the C: drive off fresh for Win7 without any vistiges of previous installs. You can't do that out of Windows.
What could be easier than using the XP CD to delete the partition and then rebooting from the Win7 disk?
Am I missing something?
Old August 10, 2009, 03:04 PM
gingerbee's Avatar
^ I think so
Old August 10, 2009, 03:09 PM
Nodscene's Avatar
You have the option when installing Windows 7 to format the hard drive. It would be easiest and best to do it then.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Old August 10, 2009, 03:23 PM
shayan288's Avatar
Sorry, no its just that I dont have a CD of such and I do not know how to
If I do that, there will be no windows old folders right? and itll be jsut like when I bought it?
The 288
Gigabyte EP45 UD3P
Antec 1200
XFX HD5970
Old August 10, 2009, 03:45 PM
Perineum's Avatar
The hard drive will, for your purposes, be as clean as when you bought it after a format which you can do during the install of Windows 7.
It'll likely ask you where you want to install it. You may have to delete the partition on the drive and then recreate the partition again. You would then format that partition and install the new OS on top of that.
Everything on your drive will be gone and you'll end up with a brand new fresh install.
Old August 10, 2009, 04:23 PM
shayan288's Avatar
Cool, thanks so much guys!
The 288
Gigabyte EP45 UD3P
Antec 1200
XFX HD5970
Old August 10, 2009, 05:39 PM
Perineum's Avatar
I see you're in Vancouver area. If you get stuck and are frustrated I could swing by and help you out if you like. Met a few people off here already, it's been interesting
Failing and new hard drive question matsta31 Storage 10 January 19, 2009 06:54 PM
sata hard drive formatting issue in XP sirhc Troubleshooting 28 October 9, 2008 12:37 PM
DirectCanada: Hard Drive Order Question MAC Off Topic 3 May 16, 2008 08:16 PM
format hard drive question Jamz O/S's, Drivers & General Software 6 March 26, 2008 11:29 AM
Question on upgrading computer, saving the hard drive ShinseiKen Troubleshooting 7 August 2, 2007 01:25 PM
