Old July 30, 2009, 06:49 PM
Originally Posted by Jake_HT View Post
You can install win7 onto the hard drive, after you format it.. there will be an option to do so after it loads. No need for linux.
ahh ok.
so im at this windows 7 screen... asking where do i want to install it.... that is the format right? once i choose.... it is being formated right?
Infiniti's Avatar
Yeah, once you pop in the disc for Win 7 and you get to the installer, you just keep on continuing on, and then when you get to the Select Drive part, you should see an unallocated space. You then click on More Options and click on Format and just follow the steps there.
Old July 30, 2009, 06:51 PM
oopz... i didnt click on more option. at the screen where it show unlocated partition... showing where i want to install.... i just quickly click next. then it is installing show percentages.
am i in trouble? or ok?
Old July 30, 2009, 07:09 PM
Jake_HT's Avatar
It must've been already formatted, in that case it's fine.. you'll still have your old files and stuff still, no big deal...
We were assuming the HDD was new/ unformatted... if it's installing you're good to go!
http://jakeht.deviantart.com/
Old July 30, 2009, 07:21 PM
yeah it is brand new. unuse hdd. super brand new sealed.
well im all set! turns out nothing to worry about. everything running smooth!
tqtq case closed.
How fast is your internet browser? m0pelley99 O/S's, Drivers & General Software 18 July 13, 2009 02:56 AM
OPENDNS * FAST * fefox Networking 5 June 19, 2009 08:09 PM
Its actually fast now Eagle Eye Off Topic 14 May 9, 2009 12:11 AM
Wow! SSDs are fast! zlojack Storage 13 April 3, 2009 08:35 AM
The Barcelona is fast, REALLY FAST!: AMD Babrbarossa Press Releases & Tech News 2 April 25, 2007 08:02 AM
