I ran a SMART check, and got these results:
smartctl version 5.38 [i486-slackware-linux-gnu] Copyright (C) 2002-8 Bruce Allen
Home page is smartmontools Home Page (last updated $Date: 2009-08-11 23:46:20 +0200 (Tue, 11 Aug 2009) $)
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Scorpio family
Device Model: WDC WD2500BEVS-75UST0
Serial Number: WD-WXC708A52824
Firmware Version: 01.01A01
User Capacity: 250,059,350,016 bytes
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Fri Aug 14 17:56:25 2009 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
Total time to complete Offline
data collection: (9600) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 115) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303f) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 195 195 051 Pre-fail Always - 22780
3 Spin_Up_Time 0x0003 186 186 021 Pre-fail Always - 1675
4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1617
5 Reallocated_Sector_Ct 0x0033 158 158 140 Pre-fail Always - 331
7 Seek_Error_Rate 0x000e 200 200 051 Old_age Always - 0
9 Power_On_Hours 0x0032 096 096 000 Old_age Always - 3403
10 Spin_Retry_Count 0x0012 100 098 051 Old_age Always - 1
11 Calibration_Retry_Count 0x0012 100 100 051 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 813
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 119
193 Load_Cycle_Count 0x0032 190 190 000 Old_age Always - 31773
194 Temperature_Celsius 0x0022 109 094 000 Old_age Always - 38
196 Reallocated_Event_Count 0x0032 001 001 000 Old_age Always - 243
197 Current_Pending_Sector 0x0012 192 184 000 Old_age Always - 330
198 Offline_Uncorrectable 0x0010 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 051 Old_age Offline - 0
240 Head_Flying_Hours 0x0032 082 082 000 Old_age Always - 13198
241 Unknown_Attribute 0x0032 125 125 000 Old_age Always - 75303848162530
242 Unknown_Attribute 0x0032 200 200 000 Old_age Always - 13276747170
SMART Error Log Version: 1
ATA Error Count: 56483 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 56483 occurred at disk power-on lifetime: 3403 hours (141 days + 19 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
01 51 00 f0 ec 03 e0 Error: AMNF at LBA = 0x0003ecf0 = 257264
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
c8 00 a8 70 ec 03 00 00 00:02:34.439 READ DMA
27 00 00 00 00 00 00 00 00:02:34.438 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 00 00 00:02:34.438 IDENTIFY DEVICE
ef 03 45 00 00 00 00 00 00:02:34.438 SET FEATURES [Set transfer mode]
Error 56482 occurred at disk power-on lifetime: 3403 hours (141 days + 19 hours)
c8 00 a8 70 ec 03 00 00 00:02:30.500 READ DMA
27 00 00 00 00 00 00 00 00:02:30.499 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 00 00 00:02:30.499 IDENTIFY DEVICE
ef 03 45 00 00 00 00 00 00:02:30.499 SET FEATURES [Set transfer mode]
Error 56481 occurred at disk power-on lifetime: 3403 hours (141 days + 19 hours)
c8 00 a8 70 ec 03 00 00 00:02:26.549 READ DMA
27 00 00 00 00 00 00 00 00:02:26.548 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 00 00 00:02:26.548 IDENTIFY DEVICE
ef 03 45 00 00 00 00 00 00:02:26.548 SET FEATURES [Set transfer mode]
Error 56480 occurred at disk power-on lifetime: 3403 hours (141 days + 19 hours)
c8 00 a8 70 ec 03 00 00 00:02:22.599 READ DMA
27 00 00 00 00 00 00 00 00:02:22.598 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 00 00 00:02:22.598 IDENTIFY DEVICE
ef 03 45 00 00 00 00 00 00:02:22.598 SET FEATURES [Set transfer mode]
Error 56479 occurred at disk power-on lifetime: 3403 hours (141 days + 19 hours)
c8 00 a8 70 ec 03 00 00 00:02:18.616 READ DMA
27 00 00 00 00 00 00 00 00:02:18.615 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 00 00 00:02:18.615 IDENTIFY DEVICE
ef 03 45 00 00 00 00 00 00:02:18.615 SET FEATURES [Set transfer mode]
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed: read failure 90% 3403 3586667
# 2 Conveyance offline Completed: read failure 90% 3403 3586667
# 3 Short offline Completed: read failure 90% 3403 3586667
# 4 Extended offline Completed: read failure 90% 3240 257264
# 5 Short offline Completed: read failure 90% 3240 257264
# 6 Short offline Completed: read failure 70% 3164 257264
# 7 Short offline Completed: read failure 90% 3164 257264
# 8 Short offline Completed: read failure 90% 3142 257264
# 9 Extended offline Completed: read failure 90% 3135 257264
#10 Conveyance offline Completed: read failure 90% 3135 257264
#11 Short offline Completed: read failure 90% 3135 257264
#12 Conveyance offline Completed: read failure 90% 3135 257264
#13 Conveyance offline Completed: read failure 90% 3135 257264
#14 Short offline Completed: read failure 20% 3135 257264
#15 Short offline Completed: read failure 50% 3135 257264
#16 Short offline Completed without error 00% 2298 -
#17 Short offline Completed without error 00% 3 -
#18 Short offline Completed without error 00% 2 -
#19 Short offline Completed without error 00% 0 -
#20 Short offline Interrupted (host reset) 80% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
that's all a bit beyond me, does this shed any more light on my problem?
