Old July 15, 2009, 04:55 AM
FrankyG's Avatar
Default Hardware RAID 5 card
I am looking for a hardware RAID 5 card with atleast 4 sata ports. What you you guys sugest I have a budget of around 300 to 350. It can be PCI or PCI-E.
Thanks !
Intel i7-5820K, MSI X99 SLI Plus, 16GB DDR4, Geforce GTX980
Old July 15, 2009, 08:57 AM
lowfat's Avatar
Buy a Dell PERC 5/i from ebay. Definitely the best value out there.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old July 15, 2009, 10:15 AM
I'm going to pipe up here and say something you don't often hear: DON'T DO RAID 5.
Do RAID 0+1 instead.
Reasons:
1) Disk is cheap. It costs trivially more to get a fourth disk. Sure, you've lost more of your disk space than with 5, but the remaining benefits (I think) outweigh this and the costs substantially.
2) You're looking to get a 4-port device anyway.
3) When a disk fails in 5, the hardware still has to calculate the missing data from the RAID hash data stored on the remaining two. This will cause a substantial performance decrease, even in a hardware card.
4) When a disk fails in 5 and is replaced, the hardware will have to rebuild ALL of the missing data. Again, this will cause a massive performance decrease during this time.
5) When a disk fails in 0+1 and is replaced, there is no calculations to be done, just a simple copy. You'll probably see a mild performance decrease, but nothing on the order of what you'll see with 5.
6) This one is anecdotal, but still holds valid I think: I had a RAID 5 array fail on me once, and it never recovered properly. This was probably due to the way it was set up and the hardware it was on rather than anything else, but it still turned me off of 5 pretty much forever.
Those are my reasons. Personally, I'll never use RAID 5 and always go with 1 or 0+1.
-r-
Old July 15, 2009, 10:19 AM
LionRed's Avatar
Had a raid 5 fail on me a couple a times one yr. Recovered fine once.....failed to recover on the other. :help:
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy!
Old July 15, 2009, 11:48 AM
FrankyG's Avatar
Ok then in that case a 0+1 card is way cheaper so RAID5 or RAID 0+1
Old July 15, 2009, 11:59 AM
Perc5i w/BBU off ebay...
PERC 5/i RAID Card: Tips and Benchmarks - Overclock.net - Overclocking.net
heatware
Old July 15, 2009, 03:14 PM
FrankyG's Avatar
Originally Posted by zoob View Post
Would any SAS cable from NCIX or whatever fit on those cards.
Old July 15, 2009, 04:50 PM
lowfat's Avatar
19.69" | 50cm Supermicro SAS to SATA Cable with Sideband For HDD, SFF-8484, Black, SAS Data Transfer Cable (CBL-0175L-01) in Canada - Fast Shipping 1.866.800.8060
these are the ones you want.
Queen of Dreams WIP
Big Lian Li
Complete
Old July 15, 2009, 05:50 PM
LSI MegaRAID = most compatible / reliable
Most DELL PERC cards use LSI chips anyways :)
I confirmed the LSI MegaRAID can access/convert the Intel ICH10R generated RAID5 arrays (raid internal to Core I7 X58) systems.
Old July 15, 2009, 06:57 PM
Really???? ARGH. That would have saved me a lot of time...
heatware
do I need raid card? bumfloss Storage 11 June 27, 2009 05:14 PM
do i need a raid card for a server. kyle_L Storage 15 April 1, 2009 12:21 PM
Which Hardware RAID5 Card? CanadaRox Storage 12 August 3, 2008 12:26 PM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
looking for a raid card that does 0+1 cujo Storage 0 March 10, 2008 11:14 AM
