<~----> Hardware RAID 5 card - Page 2 - Hardware Canucks
Old July 15, 2009, 08:31 PM
grinder's Avatar
with the drop in price per GB i have been using raid 10 more and more. The controller cards are cheaper and the performance is faster like RyanJ said.
Old July 16, 2009, 02:54 AM
FrankyG's Avatar
Thanks guys I will definitely look into that. Those PCI-E X4 & X8 cards they should work in a X16 slot right ?
Intel Core I7 X980 W\Noctua Cooler
ASUS Rampage III Extreme
8GB DDR3 Corsair
3x GTX480 SLI
120 SSD
Sound Blaster XFI
1200W Antec PSU
Old July 16, 2009, 08:18 AM
grinder's Avatar
they certainly will!
Old July 16, 2009, 09:11 AM
Originally Posted by FrankyG View Post
Ok then in that case a 0+1 card is way cheaper so RAID5 or RAID 0+1
Poster got it reversed.. RAID 1+0 (stripped set of mirrored drives) is preferred over 0+1 for best performance with redundancy. However, 1+0 is usually not on software or cheap cards.
For storage over performance, you want RAID5 (for 1 to 10 drives) and RAID6 (for 10 + drives)
Old July 19, 2009, 04:36 AM
FrankyG's Avatar
Well I bought a 3WARE 9650SE 4 port, I did some researche on the dell card recommended above but it would not support the board on the PC its going in so I went with the 3WARE
8GB DDR3 Corsair
3x GTX480 SLI
120 SSD
Sound Blaster XFI
1200W Antec PSU
Old July 19, 2009, 10:05 AM
lowfat's Avatar
Just an FYI the Dell card works on anyboard with a bit of electrical tape.
Old July 19, 2009, 11:38 AM
@Lowfat: On the performance side, what will be faster in the same price range, 4x wd black 640 in raid with the dell card in the post or 1x 120gb vertex?(even, 2x 60gb vertec on ud5 onboard raid for 30$ more...)
Thanks
Phil
Old July 19, 2009, 11:50 AM
lowfat's Avatar
Easily the Vertex.
  #19 (permalink)
Old July 22, 2009, 01:17 PM
nka nka is offline
I got those, wondering if the Dell PERC 5/i is faster in RAID10 ?
do I need raid card? bumfloss Storage 11 June 27, 2009 05:14 PM
do i need a raid card for a server. kyle_L Storage 15 April 1, 2009 12:21 PM
Which Hardware RAID5 Card? CanadaRox Storage 12 August 3, 2008 12:26 PM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
looking for a raid card that does 0+1 cujo Storage 0 March 10, 2008 11:14 AM
