Old July 12, 2009, 12:56 AM
Is it possible you have a bad drive in your array?
Old July 12, 2009, 06:53 AM
LionRed's Avatar
What happens when you just unplug the 750GB drive....but leave the drives you use for raid 0 plugged in?
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy!
Old July 12, 2009, 10:29 AM
kyle_L's Avatar
the drive i dont think is bad, now that i got some sleep i will be trying to figure out why i cant install anything on the one drive.
Gotta Love Timmies Coffee.
Old July 12, 2009, 10:37 AM
gingerbee's Avatar
good luck and i hope you have backups just in case.
Old July 12, 2009, 01:31 PM
grinder's Avatar
have you completely deleted and re-initialized your new array on the 640's Kyle? If you are starting over they need to be wiped clean by the raid's BIOS or setup program... partition wipe in windows setup will not do the same job.
JDrom's suggestion was bang on with the reconstructur BTW. I've had to rebuild a few botched arrays that way and it works like a charm... but it sounds like the data on your RAID 0 was mostly disposable, so not worth the software cost or effort.
Old July 12, 2009, 01:49 PM
kyle_L's Avatar
i did delete them in the raids bios, i have since talked to WD tech support and am running data life guard to erase the drive that has the problem with it.
Old July 12, 2009, 04:06 PM
kyle_L's Avatar
well ive now gone back as far as having to reintialize the drives after wiping them clean with wd tool they have, lets see if i can get it to work again.
Old July 12, 2009, 04:17 PM
kyle_L's Avatar
and that didnt work i still get the same message.
  #19 (permalink)
Old July 12, 2009, 04:23 PM
gingerbee's Avatar
is your SB working right. i just ask cause you say everything works right up to the raid controller. maybe it's your boards raid controller can you try with spare drives?
  #20 (permalink)
Old July 12, 2009, 05:13 PM
kyle_L's Avatar
i have no spare drives. from the reseach ive done with the message i think the drives are being fromated properly so im working on shriking my backup drive to put another partion on it and try working in windows on the same computer to figure it out.
Case Selection - urgent Crysisfan11 New Builds 11 February 12, 2009 08:08 AM
Urgent - Do I have Heat Issues? Please look D4ng3r CPU's and Motherboards 8 December 17, 2008 02:14 PM
Problem with SATA Raid kickz28 Storage 2 October 3, 2008 05:22 PM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
Urgent- Need Advice Tonight tom.mullie Video Cards 6 February 4, 2008 09:50 AM
