Old July 10, 2009, 09:10 PM
Originally Posted by AkG View Post
Right now the Indilinx based SSD are the best bang for your buck. Fast, powerful and have wiper.exe
Your options are G.Skill Falcon 2yr warranty....OCZ Vertex 3yr warranty....or Patriot Torqx TEN FREAKIN' YEAR warranty. All are basically the same drive....Guess which one I recommend....right now ;)
And yes...a review IS in the works of the Torqx.
relevant part (bold and underline added by me):
"...backed by a new industry leading 10 year warranty for all Torqx SSD products..."
So Torqx is just like Vertex Turbo that make minor update to the hardware. Vertex Turbo OC the ram, and Torqx slap another 64MB of ram so it's 128MB. The 10 yyrs warranty is great, but if they don't have as much as support like OCZ that pump out updates like crazy, then I would rather stick with Vertex. just my 2 cents.
Old July 11, 2009, 04:30 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
The Torx M28 has double the cache. The "regular" Torqx is exactly like the Vertex and Falcon. :)
Old July 11, 2009, 09:12 PM
FreeKnight's Avatar
Hmm.... I can get the OCZ Vertex 128GB for over $100 bucks cheaper than the torqx at my local dealer. Gonna have to go for that. Thanks for all the input peeps, you're the best :D
Moving OS from HDD to SSD artistpavel Storage 29 November 20, 2010 01:32 PM
SSD as boot drive phil3_66666 Storage 16 July 23, 2009 10:18 AM
32 gb patriot warp SSD as boot drive quikgp Storage 7 May 28, 2009 01:22 PM
new HDD noise on secondary drive after Vista reinstall? donimo Storage 6 December 13, 2008 10:57 PM
9 drive ssd raid 0 array tzetsin Storage 3 May 3, 2008 11:03 AM
