Old July 8, 2009, 09:54 PM
Default Hot Swap Hard drive
What are hot swap hard drives ?
and
Who make such a hard drive ?
Old July 8, 2009, 10:02 PM
lowfat's Avatar
Every SATA drive is hot-swapable if AHCI is enabled in the bios.
hot-swap - Google Search
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old July 16, 2009, 01:50 PM
I know this might come a little late, but (quote)Every SATA drive is hot-swapable if AHCI is enabled in the bios.(end:quote) while very true... isnt ALWAYS accurate. I've had a number of SATA drives i could hot swap out of my external usb2.0 drive bay, but would freeze my systemS<--- (meaning more than one system) anytime i tried to attatch or remove the drive from my pc via the internal sata cables. That being said, your milage may vary.
I've got 2 hitatchi 1tb drives, bought at the same time, from the same box, one will hotswap, while the other will freeze any system i've tried to hot swap it out of. I have other drives that freeze the system as well, but the hitatchi's are a good example, because 2 supposidly exact hard drives produce very different results.
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
Old July 16, 2009, 02:11 PM
thenewguy001's Avatar
We've already established in a previous thread that you also need a compatible OS and motherboard south bridge chipset to have hot-swappable SATA drives: eSata
i5 2500K @ 4.0 GHz
2 x 4GB G.Skill Ripjaws X
Patriot Pyro 240GB
Gigabyte HD 6970 OC
Gigabyte Z68X-UDH3-B3
Seasonic 760W
Coolermaster Hyper 212+
CM690 w/ 1-80mm, 6-120mm fans.
Old July 16, 2009, 02:51 PM
lowfat's Avatar
something is wrong with the drive or the port then. I actually ment to say that all Sata 3Gbps drives are hotswapable.
Queen of Dreams WIP
Big Lian Li
Complete
Old July 16, 2009, 04:47 PM
I just wanted to illustrate the fact that you can expect that the odd time your going to come across one that just wont do it for ya. (for whatever reason)
Old July 18, 2009, 12:20 PM
JimboToronto's Avatar
With the right equipment even PATA HDDs can be "hot-swapped".
I mounted a PATA mobile HDD rack in a 5.25" USB2 drive enclosure.
I can leave it connected to a system, power down the enclosure, swap HDDs, and then power up the enclosure without rebooting.
Voila. Instant "hotswap".
Old July 18, 2009, 12:26 PM
lowfat's Avatar
You are talking about USB though. All USB is hot swap capable. We were talking SATA/eSATA.
Queen of Dreams WIP
Big Lian Li
Complete
Old July 18, 2009, 12:39 PM
Yeah, that's why I put "hotswap" in quotes.
rebuilding my hard drive tzetsin Troubleshooting 17 June 20, 2009 05:46 PM
[WTB] hard drive for laptop CTA Buy/Sell & Trade 14 April 1, 2009 12:44 PM
Hard drive WolfBane Storage 8 July 24, 2008 12:08 PM
Hard Drive Crusher Hardware Canucks Press Releases & Tech News 0 May 2, 2008 12:50 PM
ftp to Hard drive opj38 O/S's, Drivers & General Software 1 July 10, 2007 10:39 AM
