Old July 6, 2009, 01:54 PM
Default SSD as boot drive
Hi guys, im looking for ssd, to be clear, the vertex/falcon/torqx
but im on a budjet, 2x 120gb is not a option for that reason
my actual partion tke 135gb on my hard drive(wd black 640)
so my question is, can i buy an 60gb, install windows and principal thing who need speed on it and instal other program like office on my 640gb?
in fact, i want speed in windows and in gaming
also my board is an ex58-ud5, does the onboard raid controler are good?
does 2x 30gb ssd in raid 0 will be bether? does raid risk is a good compromise for speed?
also, another question for raid 0 on my board, it's possible to do a raid of 3x 30gb (to make 90gb) maybee lather for an upgrade?
Thanks
Phil
Old July 6, 2009, 02:19 PM
gingerbee's Avatar
i would run 2xssd in raid0 then install all your apps on the 640 hd. and yes your southbridge is ich10r good to go. and to your final question yes you can add a 3rd ssd later that's what i did. ( if it's in your budget go with the vertex 2x30gb then add 1 later.) hope that helps.
Old July 6, 2009, 02:25 PM
thanks a lot, that is exactly the anwser i want loll, only one more question, 2x30gb in raid 0 speed is a good investisment over 1 60gb?
Thanks
Phil
Old July 6, 2009, 02:36 PM
gingerbee's Avatar
i think so i don't think that there's a speed jump until the 120gb. so yes 2x 30gb will be faster( short answer yes)
Old July 6, 2009, 02:39 PM
gingerbee's Avatar
i plan on upgrading to the vertex or something faster around Christmas.
Old July 6, 2009, 02:49 PM
thanks again, and belive me, youre not the slowest here
Old July 6, 2009, 03:35 PM
gingerbee's Avatar
lol thanks
Old July 21, 2009, 09:04 AM
JimboToronto's Avatar
At the rate of SSD evolution, the Vertex will be a dinosaur by Christmas.
Old July 21, 2009, 10:31 AM
gingerbee's Avatar
So true
Old July 22, 2009, 03:11 PM
once you have taste raid 0 you wouldn't return to single disk
im on raid 0 on all my rigs
anybody using a Vertex as boot drive? dadzilla Storage 5 June 20, 2009 02:23 PM
32 gb patriot warp SSD as boot drive quikgp Storage 7 May 28, 2009 01:22 PM
Help NEED A BOOT CD IN THE DRIVE TO START WINDOWS!!!! Madeinedmundston Troubleshooting 12 December 5, 2008 03:39 PM
9 drive ssd raid 0 array tzetsin Storage 3 May 3, 2008 11:03 AM
HD strickly as a boot drive Nodscene Storage 6 March 28, 2008 06:04 AM
