Old June 13, 2009, 12:02 PM
Default External Hardrive Freezing "My Computer"
My Acomdata 160GB won't load properly anymore when I turn it on. I can't seem to access/view the data when I turn on the hard drive. It ends up freezing "My Computer" when I turn it on. Is there anyway I can recover my data? I've tried some software programs but they also cannot read the external HDD.
I also tried sticking it in my freezer, but still no luck.
Would opening the case do any good?
Old June 13, 2009, 12:16 PM
have you tried removing hdd from enclsure and install in pc..
maybe enclosures pooched
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old June 13, 2009, 01:38 PM
dhoshaw's Avatar
I've had a couple of external enclosures die on me; in all cases, the drives were still working.
Intel Q9550 @3.8 GHz
Sapphire 5850 Toxic
XFX 9800GX2
Xigmatek Dark Knight
Gigabyte GA-EP45-UD3P
2 x 2 GB Corsair XMS2 1066C5
2 x WD 640 GB Raid 0 + WD 1 TB
Haf 922 / Antec Signature 850
Windows 7 Ultimate x64
Old June 13, 2009, 02:51 PM
Ok I took the drive out, it's an IDE and I have SATA as bootable, and my Bios is trying to boot from the IDE. I changed the BIOS settings. Specifically, I went into advanced changes the "Controller Mode" from IDE to RAID. Was this correct? B/C windows now boots fine.
But when I go to management setting and try to rescan disk, the IDE drive does not appear.
Also I forgot to note, when I first put in the drive and was able to access windows. There was a prompt about updating the drive, but it talked about instability. I tried to get it back but to no avail. The IDE drive doesn't seem to be appearing in the BIOS. Do i have to set it to master for it to appear? I'm new to this.
Old June 13, 2009, 09:46 PM
martin_metal_88's Avatar
try external IDE/USB adapter like this one
Welcome to Vantec ? Leading Brand of Storage, Thermal, and Mobile Accessories! - Product
They are working realy well and disk never get to hot because...he lay on your table:) I like this little shit more than all my external HD, exept my lacie 2Big Tripple Network Raid storage;) that's, what I call a beast.
Regard
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old June 25, 2009, 05:35 PM
The BIOS setting should be AUTO and usually you would see it listed in the BIOS. If everything in your PC is SATA then setting that IDE drive to master is fine. It can be a slave too since it's the only IDE device in your system. When your system POST's it should be displaying the IDE drive model but these screens go by really fast. Make sure the red stripe on the IDE cable is facing towards the power connector of the HD. The best thing to try is to download GParted, burn to DVD and boot from it. This will show you all your drives even when connected with USB. If you get it going download Speedfan and do an analysis of your drive to see any problems.
Google Warnings- "This Site may harm your computer" CasheKicker Off Topic 19 February 2, 2009 11:07 AM
"Computer Friends" Andy Off Topic 4 November 27, 2008 11:58 PM
2nd HDD wont show up in "My computer" Lima Storage 3 October 11, 2008 08:38 PM
"Great deal on LG 26" Monitor @ BestBuy" CTA Computer & Electronics Hot Deals 7 September 9, 2008 12:52 AM
"Girly" 2.5" IDE Enclosures encorp Storage 13 July 14, 2008 10:19 AM
