Old May 30, 2009, 12:11 PM
Jackquelegs's Avatar
Default Help with RAID 1
I recently put 2 WD blacks in RAID 1 for OS.
I am currently using Acronis to clone the original OS drive to the new Array.
Will that work? Or do I have to reinstall the OS?
Thanks
Iapetos
Zephyranthes
Old May 30, 2009, 12:41 PM
NyteOwl's Avatar
It should work if the RAID drivers are installed in the OS (I'm assuming Windows). You may end up playing a bit of a driver dance to get everything working properly otherwise.
Obsolescence is just a lack of imagination.
Old May 30, 2009, 12:44 PM
Ugh,I gave up on it, takes too long heh
Iapetos
Zephyranthes
Help on Raid set-up Malam Storage 4 December 9, 2008 01:13 AM
raid 5 expansion Tazer-[X] Storage 2 October 12, 2008 10:01 PM
RAID question miggs78 Storage 17 August 30, 2008 03:12 AM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
raid help Jhayman Troubleshooting 9 November 8, 2007 01:10 PM
