Old May 20, 2009, 09:54 PM
Default do I need raid card?
with 4 of these Newegg.ca - Patriot Warp PE32GS25SSDR 2.5" 32GB SATA II Internal Solid state disk (SSD) - Solid State Disks will I need a raid card for raid 0 or will the onboard chipset of this motherboard do it?-----Newegg.ca - ASUS M4A79T Deluxe AM3 DDR3 AMD 790FX ATX AMD Motherboard - AMD Motherboards
Old May 20, 2009, 10:06 PM
Originally Posted by bumfloss View Post
The price of a raid card that you'd be willing to probably buy would be no better than onboard.
Old May 20, 2009, 10:35 PM
so your point is....
should I stick with 3 in raid 0 or get a 4th will I see an increase with performance?
Old May 20, 2009, 10:39 PM
Phobia's Avatar
a good raid card is 300+
Old May 21, 2009, 12:16 AM
lowfat's Avatar
Do you already have the SSD's? If not it would be much better to buy a drive like a 120GB Vertex. Jmicron drives on onboard RAID can be pretty risky in terms of performance. Depending on your usage, stuttering can happen.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old May 22, 2009, 12:21 PM
lcdguy's Avatar
actually a good one now is probably closer to $400-$500 starting. For RAID 0 onboard is fine. You really only need a dedicated raid card if your doing something like raid 5, 6, 30, 50, etc.
Old May 22, 2009, 12:31 PM
If your serious about RAID you should be running a dedicated card period.
Onboard aka software RAID is junk.
Old May 22, 2009, 01:10 PM
gingerbee's Avatar
my answer would be to buy 2 vertex 30 gb and use onboard
Old May 22, 2009, 01:54 PM
lcdguy's Avatar
which is why my raid is run by my 3ware card cost me 430 bucks.
Old May 22, 2009, 03:30 PM
grinder's Avatar
onboard will do bumfloss. If your doing raid higher than 1 on your motherboard an aftermarket raid card would be advised. Something in the $350+ dollar range for a RAID card will give you the performance you want for RAID 5 or RAID 10, otherwise the net gain in performance will be moot.
[FS] HAF932, HTPC Case, Raid Card, 750 PSU ect... ikeenen Buy/Sell & Trade 13 May 1, 2009 09:08 PM
do i need a raid card for a server. kyle_L Storage 15 April 1, 2009 12:21 PM
WTB: Video Card/Sound Card/Hard drive - Look here if u gotz some ! Flintblade Buy/Sell & Trade 4 December 4, 2008 10:27 PM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
looking for a raid card that does 0+1 cujo Storage 0 March 10, 2008 11:14 AM
