-   Storage (https://www.hardwarecanucks.com/forum/storage/)
-   -   Help me backup my stuff faster! (https://www.hardwarecanucks.com/forum/storage/17897-help-me-backup-my-stuff-faster.html)
Delavan May 13, 2009 05:15 PM
Hi all!
I just built myself the rig in my sig. I picked a Quad for it's number crunching capabilities, so to speak. Because it's supposedly faster at encoding than a C2D, my expectations were high. I now try to "archive" one of my personal DVD and see if the Quad is faster than my oldie C2D E6420@3.2.
Anyway, it doesn't feel like it. Just for kicks, I tried to Decrypt, then shrink my DVD, and the 4 cores are working pretty much evenly. I doesn't seems like I'm going thru the process faster...
My DVD Rewriter is this one:
NCIX.com - Buy LG GH22NS30 Black DVD+RW 22X8X16 DVD-RW 22X6X16 DL 16X/12X 2MB SATA OEM - GH22NS30 BLACK In Canada.
Maybe there is a setting, something I forgot, a check in a box or something, or my apps aren't making good use of the OCed Q9550.
I was expecting faster results.
Alao, my burner burns slow! I choose max speed (16X) and still, SLOW...
Any ideas?
JD May 13, 2009 05:54 PM
If the program isn't mulit-threaded, then no it won't be any faster on a quad vs a dual. Also it could very will be hard drive limited.
As for burning, it's slow no matter what. That's just how it is.
saltyvinegar June 16, 2009 02:36 PM
Only a faster drive will make burning faster.
Perineum June 16, 2009 03:46 PM
If you buy slow media then it will only burn at the rated speed.... at least I haven't found a way of overriding it. Even if I could override it not sure if I would anyway.
I buy verbatim 2.4 speed dual layer discs and it takes a verrrrry long time
gingerbee June 16, 2009 04:04 PM
backup to a hard drive that will make it faster. and cheaper
lcdguy June 17, 2009 09:12 AM
i would get another drive and mirror your hdd then just due a weekly backup to dvd. (Thats what i do kinda,)
grinder June 17, 2009 12:18 PM
he's not backing up his data.. he's backing up his movies by making playable copies for his dvd player.
i think Perinium hit it when he said you might be using slow media to burn. Not all DVD-R's are alike. You are using 16x blanks right?
jdrom17 made a good point too. I noticed when i am crunching a DVD it runs much faster if the source files are on one physical HDD and the target files save on a different physical HDD before burning. THis may or may not apply to your setup or "backup" process. User discrecion applies.
lcdguy June 17, 2009 12:45 PM
opps, i didn't see that part. I have found that some drives are faster than others. Also i have found that sometimes nero drive speed helps speed the drive up a bit.
