Old May 8, 2009, 04:07 PM
Default USB 2.0 TO SATA IDE CABLE does not work properly
Hi
I tried to use new branded “R-Driver III” USB 2.0 TO SATA IDE CABLE device with Laptop HD and Desktop HD (I set it to slave) but it did not show me the HD , although I checked Disk Management.
I thought the problem with “ R-Driver III ”, about another one branded as Ritmo
Still the same problem is going on with both Hard Disks
Both hard disks are working if I hook them into a computer
Any thought would be appreciated
Thanks
Old May 8, 2009, 04:43 PM
dataxpert's Avatar
what you means by setting it to slave, are you telling us you put both the 2.5 and the 3.5 drive at the same time........?
Old May 8, 2009, 05:05 PM
I am plugging one device only not two devices at the same time.
When I plugged the 3.5, I set it to master when it did not work , I tried to set to slave to see if it works or not, but it did not work
Old May 8, 2009, 05:20 PM
3.0charlie's Avatar
Did you connect the external powersource.
Did you try different USB ports off the back of your computer, not the ones on the case.
Only use SATA drives for the time being.
Old May 8, 2009, 05:40 PM
I used it for 3.5 yes, , because without powersource , it did not work, and i can hear spinning of the HD.
But for 2.5 there is not place for external powersource, and I can not hear hd spinning when I plug it to the computer.
Yes, BTW I have got new Gigabyte motherboard 6 months old
I did not get that.
Old May 8, 2009, 05:46 PM
3.0charlie's Avatar
You mentionned the slave jumper; only IDE drives have slave settings, hence why I mentionned to only use SATA drives for the time being. It's easier to troubleshoot.
When you connect the drive, is it with your computer shut down? When you restart and access the BIOS, does the drive show in the HDD section?
Old May 8, 2009, 05:54 PM
dataxpert's Avatar
You not suppose to see the usb drive in the bios
did your computer detect the usb interface, the computer have to install a driver, in device manager , you should see a USB Mass Storage Device in USB section
....... When you restart and access the BIOS, does the drive show in the HDD section?
Old May 8, 2009, 06:03 PM
I see, I do not have SATA HD handy right now, both 2.5 and 3.5 are IDE
I will try this and let you know
Old May 8, 2009, 06:04 PM
3.0charlie's Avatar
You have to shut down the computer before connecting a HDD.
Old May 8, 2009, 06:23 PM
dataxpert's Avatar
3.0 this is not a HD, I means it's like an external enclosure for HD ( iwhtout the enclosure ) , they work USB , so you plug them when the computer is boot. the computer will indicate installing new device, and only after you will see the drive. The OP sais they work when plug direct without the interface I just read some instruction, the drive have to be set as master....
MTB with 2 connector IDE and 4 SATA dataxpert CPU's and Motherboards 3 April 18, 2009 10:01 PM
IDE instead of SATA... whoops. somecanadianguy New Builds 15 April 2, 2009 07:37 PM
Can't get FLAC files to work properly biff HTPC Systems & Software 4 March 15, 2009 09:31 AM
3.5" USB Hard Drive Enclosure (IDE) tester3000 Buy/Sell & Trade 4 August 1, 2008 08:58 PM
SATA to IDE.... chibi_man Troubleshooting 9 October 20, 2007 11:02 AM
