  #21 (permalink)
Old May 16, 2009, 04:51 AM
I tried the USB device and HD 3.5 on my friend's laptop and it worked fine without any problem.
His OS is XP , does not have any utilities installed on his laptop , unlike mine which I have got heaps of utilities.
Therefore he told that might be my problem,,,,Any input for such type of suggestion ?
  #22 (permalink)
Old May 18, 2009, 10:54 PM
Thanks buddy for the inputs and trying to help.
To share a knowledge for whom might experience same issue the problem is solved and credit goes to
USB 2.0 TO SATA IDE CABLE does not work properly - SysOpt Forums
MTB with 2 connector IDE and 4 SATA dataxpert CPU's and Motherboards 3 April 18, 2009 11:01 PM
IDE instead of SATA... whoops. somecanadianguy New Builds 15 April 2, 2009 08:37 PM
Can't get FLAC files to work properly biff HTPC Systems & Software 4 March 15, 2009 10:31 AM
3.5" USB Hard Drive Enclosure (IDE) tester3000 Buy/Sell & Trade 4 August 1, 2008 09:58 PM
SATA to IDE.... chibi_man Troubleshooting 9 October 20, 2007 12:02 PM
