Old May 8, 2009, 06:31 PM
You have to shut down the computer before connecting a HDD.
I did but it did not work.
they work USB , so you plug them when the computer is boot. the computer will indicate installing new device, and only after you will see the drive.
Did only once for 3.5 but still I can not see it.
The OP sais they work when plug direct without the interface
Definitly it works.
the drive have to be set as master....
I tried that as well
Old May 8, 2009, 06:37 PM
dataxpert's Avatar
master stand alone or master with slave, it have to be stand alone.....
you don't awnser me, did you see a mass storage device in USB section of the device manager. ?
Old May 8, 2009, 06:46 PM
Sorry , please see the picture below
ImageShack - Image Hosting :: usbc.jpg
Old May 8, 2009, 07:09 PM
Now I can see it in the device manager , but I can it access it freezes the my computer
Old May 8, 2009, 07:25 PM
dataxpert's Avatar
It freeze because the jumper is not adjust properly.
the computer is not freeze, he just don't understand the HD setting.. it happen also with HD connect directly on the MTB, often the computer will not even post if the jumper is not set properly. give me exactly the model of hard drive you have , I'm gone tell you how to set the jumper
Old May 8, 2009, 08:31 PM
Nodscene's Avatar
If it's freezing your computer then try it on a laptop or another computer. The enclosure may be fried. I've had a few issues like yours and it's either the hard drive or enclosure.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Old May 8, 2009, 10:52 PM
Which postiton should I set a jumper , now it is on master.
On slave did the same thing
Old May 8, 2009, 10:55 PM
Both eclosure !!
  #19 (permalink)
Old May 12, 2009, 08:00 PM
When I connected USB 2.0 TO SATA IDE CABLE to my laptop (before it was being connected to desktop),,,I received this message :
ImageShack - Image Hosting :: diskgforsamsunghd.jpg
ImageShack - Image Hosting :: diskmanagemnetforsamsun.jpg
  #20 (permalink)
Old May 12, 2009, 08:09 PM
Yes they have stated here as you have mentioned
Technology: R-Driver III USB 2.0 to SATA IDE Cable
MTB with 2 connector IDE and 4 SATA dataxpert CPU's and Motherboards 3 April 18, 2009 10:01 PM
IDE instead of SATA... whoops. somecanadianguy New Builds 15 April 2, 2009 07:37 PM
Can't get FLAC files to work properly biff HTPC Systems & Software 4 March 15, 2009 09:31 AM
3.5" USB Hard Drive Enclosure (IDE) tester3000 Buy/Sell & Trade 4 August 1, 2008 08:58 PM
SATA to IDE.... chibi_man Troubleshooting 9 October 20, 2007 11:02 AM
